Newbie 85 f250 frame off resto (Image Heavy) - Page 10 - Ford Truck Enthusiasts Forums
  #136
Old 02-20-2014, 11:43 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
See if you can send it back, it's not worth trying to mess it up to plug those holes. If you don't plug them, lots of exhaust will be coming out of those holes.
  #137
Old 02-20-2014, 11:45 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
It's already been installed though, do you think they will take it back?
  #138
Old 02-20-2014, 11:46 PM
Quote:
Don't tell them it's been installed, just say it's new and never used. Technically it hasn't been used yet.
  #139
Old 02-20-2014, 11:52 PM
I give it a try.
Another question. If I have a sending unit in my tank do I need the mech pump?It had both to begin with.
  #140
Old 02-20-2014, 11:55 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Edelbrock said that manifold is a direct replacement for the 4V HO manifold. That being the case the exhaust gas comes up through that hole and into the EGR valve itself. Lots of guys on here have made block off plates with everything from a Coke can to stainless steel sheet. You will need a gasket on the manifold, your block off plate, another gasket, and then the carb. And the bottom gasket has to fully cover the hole, as does the plate.
  #141
Old 02-20-2014, 11:57 PM
Gary Lewis's Avatar
The sending unit, meaning just the float and resistor combo, is used with a mechanical pump on the engine. The in-tank electric pump usually includes the sending unit and you don't need the mechanical pump on the engine.
  #142
Old 02-21-2014, 12:01 AM
Quote:
Seems like a lot of potential for leaks. Intake, gasket, plate, gasket, spacer, gasket, and carb.
  #143
Old 02-21-2014, 12:03 AM
I tried sliding the mech pump in the timing cover today and it doesn't seem to want to go in. Any tricks?
  #144
Old 02-21-2014, 12:14 AM
Gary Lewis's Avatar
There are potential for leaks, but it can and does work. You might find a commercial block off plate that is less likely to leak.
The arm on the pump is hitting the actuator cam and you are compressing the spring in the pump as you tighten the bolts down. Turn the engine half a turn or so and see if it gets easier. There are points in the engine's revolution where the arm is just barely compressed and places where it is highly compressed - which is where you probably are.
  #145
Old 02-21-2014, 12:16 AM
martin72's Avatar
martin72 martin72 is offline
martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.
Trucks coming right along looks good.
  #146
Old 02-21-2014, 12:25 AM
Your the best! I'd be lost without everyone on FTE........let's face it I'm lost anyway
Quote:
Thanks! I'm at a point where everything seems to be giving me trouble right now
  #147
Old 02-21-2014, 09:07 AM
Ok, so I peeled the intake of the motor and it's not that bad. The RTV should clean up no problem.
I believe the one I need is #2181. Before I order the new one, should I know anything else?
  #148
Old 02-21-2014, 09:10 AM
Gary Lewis's Avatar
I agree you want the non-EGR unit, and if that is 2181 then go for it. I can't think of anything else.
  #149
Old 02-21-2014, 01:49 PM
I found a spacer to use with the installation tool and I'm trying to get the harmonic balancer on I think it's all the way on but the pulleys don't seem to line up correctly.
I measured the depth of the stub on the back of the balancer and I don't think it can go in any more. Why don't the pulleys line up? Am I missing something?
  #150
Old 02-21-2014, 04:50 PM
Cole Neese's Avatar
Cole Neese Cole Neese is offline
Cole Neese is starting off with a positive reputation.
In the top picture, is the inside of the balancer flush with the crank snout? I can't tell from the pic. If it's not I'm pretty sure it needs to go farther.
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
