GPS not working - Ford Truck Enthusiasts Forums
Ford In-Vehicle Tech Discussion area for Ford Sync, Sync AppLink, MyFord Touch, Ford Supplied SiriusXM Radio, Ford Work Solutions, etc.
GPS not working
Old 09-15-2013, 08:26 PM
montey2005 montey2005 is offline
montey2005 is gaining momentum as a positive member of FTE.montey2005 is gaining momentum as a positive member of FTE.
GPS not working
Have a 2012 f250 with MyTouch and yesterday I noticed the GPS has no signal. I've looked for the "hard" reset but can't find it. I'm hoping that's all I need but if anyone has had the same experience please chime in. Instructions on hard reset would be welcomed please.
Thanks
Old 09-18-2013, 06:19 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Moving thread to Ford In-Vehicle Tech forum to get you some help.
Old 09-19-2013, 09:00 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
There is a TSB for certain models of vehicle, like my 2013 Taurus, there is an update to the GPSM (GPS module) software to cure an issue like this one. There was also a TSB (not for the F-series that I know of though) where the GPSM was too close to some other module, and fitting a revised mounting bracket fixed it. Then, there are people who report that the satellite antenna needed to be replaced.
I've found that even though a "master reset" was done through the MyTouch screen, it doesn't completely reset everything. The only way to get everything in one shot is to disconnect the battery for a 1/2 hour or more and then reconnect and see if it helps.
In my Taurus, the SiriusXM traffic display wouldn't get data, and a master reset didn't clear it up. The only thing that worked was pulling the battery cable. Of course, I probably could have found the fuse to the navigation system, but it was easier to disconnect the battery for an hour
If you have the time, take it to a dealer and let them handle it.
Disconnect the battery first though, and report back !
Old 09-19-2013, 09:15 AM
thanks. I took it to the dealer and it turns out the connector under the headliner rattled loose and it could not be fitted back on so a new one was put in. I guess too much off-roading but I'd rather find these items now while it's under warranty.
Old 09-19-2013, 10:45 AM
Krewat's Avatar
Quote:
Excellent! Good luck with it
03 Navigator Radio Bignate316 1997-2006 Expedition & Navigator 0 05-25-2014 06:33 PM
Switched 12 volt connection?? mwells 2007 - 2014 Expedition & Navigator 7 05-20-2014 10:28 PM
Reset Codes 94 F-250 WhiteTiger 1987 - 1996 F150 & Larger F-Series Trucks 3 09-11-2013 11:52 AM
Kenwood / Garmin GPS question pcerra Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 08-19-2013 07:31 PM
08 gps location pinestar 1999 to 2016 Super Duty 20 12-04-2012 10:24 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
