making a 1975 ford short bed into a long bed
Old 09-15-2013, 05:36 PM
MDford's Avatar
MDford
MDford is offline
how hard is it to lengthen my frame to make it a long bed
Old 09-15-2013, 07:28 PM
Rocknthehawk's Avatar
Rocknthehawk
Rocknthehawk is offline
It's pretty easy. If you check out Craigslist, you can sell your truck and buy a longbed. problem solved.
Old 09-15-2013, 07:33 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Ziegelsteinfaust is offline
Unfortunately I agree with the guy above. Short beds are worth money, and you can get long beds cheap.
Old 09-15-2013, 07:35 PM
march's Avatar
march
march is offline
Rocknthehawk X2. Driveline, brake line, fuel lines, wiring harness, e brake cable, bed mounts..................
Old 09-16-2013, 03:38 AM
BruteFord's Avatar
BruteFord
BruteFord is offline
I have a much easier solution, you give me the short bed truck, I'll give you a long bed truck.
Old 09-16-2013, 05:42 AM
jim collins's Avatar
jim collins
jim collins is offline
Help somebody else out and trade it for a long bed . You can probably get a little cash along with the long bed depending on the condition of both trucks.___
Old 09-16-2013, 08:34 AM
MDford's Avatar
MDford
MDford is offline
il trade it no problem its 2wd and its a crew cab frame
Old 09-16-2013, 09:04 AM
rogue40's Avatar
rogue40
rogue40 is offline
So, you have a crew cab shortbox?
Old 09-16-2013, 10:21 AM
jim collins
That information would have been helpful in the first post. I take back what i said as you don't have a short box frame as we think of them. Sounds like you have a long frame with a long cab and short box . Not sure though as you are keeping secrets and wanting information . I'm not good at guessing things.
Yes it can be made longer or shorter , how hard depends on if you can do it or somebody else.
Old 09-16-2013, 10:27 AM
MDford's Avatar
MDford
MDford is offline
ya sorry i prolly should have said that ya its a crew cab short bed frame I plain on making it into a long bed and 4x4 I just didn't know if anyone has stretched one and whats the steps to doing it
Old 09-16-2013, 11:00 AM
joshh's Avatar
joshh
joshh is offline
Personally I'd find a long bed frame and cut the rear off of both and reweld the long part to ur crew frame with proper gusseting so u only have one weld seam
Old 09-16-2013, 11:21 AM
rogue40's Avatar
rogue40
rogue40 is offline
Well, that's different.
I would sell it to the custom guys since it has become popular to put 4x4 under them and these are getting real hard to find.
But that leaves you without a crew cab.
I did find one near me but clear across the country from you. I know, not much help and this one has the Washington Green accents, but it does show there are some out there.
http://seattle.craigslist.org/est/cto/4068204130.html
Old 09-16-2013, 05:36 PM
BruteFord's Avatar
BruteFord
Probably still best to sell it and just find a crew long box.
BUT, if you must then likely the best way to go about it is to get one of the much more common and much cheaper 80-96 crew cab long box 4wd F350s and just use it's entire frame and drivetrain. Then you just need a bed, and if the short box you have is in good shape it could easily pay for the long box and then some.
I'm 99.9% sure the bed swaps, and 75% sure the cab will swap without mods. I've never done it but from what I've read it sounds vey doable and I bet someone on this forum has.
However with a plan like above you're likely still better off selling it. For what you could get for it you could probably buy a running 80-96 CCLB F350 4wd and all the dentside crew cab parts you need.
Old 09-16-2013, 06:07 PM
Sooper Camper's Avatar
Sooper Camper
Sooper Camper is offline
cut frame
move axle back
put long bed on top
booger weld in pieces of steel until everything connects again
connect everything that no longer reaches like drive shafts and brake lines
and finally
realize you ruined a rare and unique truck with hack fab.
Old 09-16-2013, 06:17 PM
jim collins
Originally Posted by Sooper Camper
cut frame
move axle back
put long bed on top
and finally
Quick Reply: making a 1975 ford short bed into a long bed
