1992 f-150 4x4 clutch slave cylinder leaking - Ford Truck Enthusiasts Forums
Old 09-15-2013, 03:41 PM
projectdagger's Avatar
projectdagger projectdagger is offline
projectdagger is starting off with a positive reputation.
hello. i have a 92 f-150 4x4 with a 302 engine that has recently been converted to a 5 speed manual transmission that was pulled from an 89 f-150 4x4. surprisingly the conversion went very smoothly, until it was time to bleed to clutch. and well it seems like the brake fluild is pouring out of it, even after the bleeder valve had been closed. i even had fluid coming out of the front of the transmission. my question, where did i go wrong. i bought at the parts new from the local oreillys. i think something is defective right out of the box, but this is my first time with a hydrallic clutch. so i am unsure
Clutch stuck to flywheel GJBain 1973 - 1979 F-100 & Larger F-Series Trucks 25 10-09-2016 10:59 AM
1996 f150 clutch gatorfoot Clutch, Transmission, Differential, Axle & Transfer Case 4 06-19-2015 07:40 AM
Is this a dragging clutch? Whats causing it? 1990fordf-250 1987 - 1996 F150 & Larger F-Series Trucks 5 12-21-2014 06:41 PM
1959 F100 4x4 Clutch overhaul in truck? chetspencer 1957 - 1960 F100 & Larger F-Series Trucks 28 09-07-2014 11:13 PM
89 f-150 clutch line from clutch master cylinder to transmission projectdagger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-06-2013 02:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
