FICM Voltage Low After Starting (set P0611)
Need some diagnostic help (or confirmation at-least) ...
So I'm driving down the road the other day, and my battery light comes on for about a minute then turns off (first time this has happened). Truck performance was unaffected. No CEL or other light was set, but I quickly checked my codes and found a P0611 (Fuel Injector Control Module Performance). I've since cleared the code, but it comes back.
At the time, I had my Edge Insight CS set to display EOT, ECT, & EGTE. Now, I'm displaying Batt Voltage & FICM Voltage instead.
What I've noticed via my Insight (Cold Start):
I'd say 1) my FICM is toast ... or at-least in the toaster (I already have a replacement PCB for my FICM on the way), and 2) I need to replace my batteries. My wonder is, do I need to look at my alternator? The most extra power I use is for a small self-enclosed subwoofer that I've tucked away inside my center console .. nothing else outside of stock.
Here's a vid of my start-up Insight readings:
- Key On Ignition Off ... Batt Voltage = 11.0-11.2V / FICM = 48.5V
- Cranking ... Batt Voltage = 9.3-11.4V / FICM = 48.0-48.5V
- Running Immediately after Cranking ... Batt Voltage = rising to 14V after GP's turn off / FICM = falling to 35V, then rising back to 48V
X4
Have batteries load tested isolated from each other.. just drive to parts store, bring 8mm socket/wrench. Remove ground from both batteries in lot, have them load test each battery. Reconnect and you are done.
It's worth replacing both batteries, THEN send the ficm to ed for repair. I also got the atlas40 ficm tune
Sounds like Everyones on track with bad Batterys
But I don't Agree the Alternator Looks OK But might be the Root cause batterys died (Of coarse 4 years on a Battery is about Max anymore after the originals died)
I'm saying the Underpowered Alternator caused the Batterys to get Overworked and Killed them Too
These OEM Alts the 110amp are underpowered Plus the 110amp is MAX Output at High RPM
So @ Idle OEM Alt only kicks out around 80-85amps
Guess Im getting at the Batterys would Last longer with a High Output alt
I guess in theory they should last longer
