need trans seals for F2
Need trans seals for F2 with Warner T-87D H/D 3 speed.
The following is the only seal in this transmission (see parts catalog pic). Other leaks probably caused by seeping gaskets.
C1TT-4813-C .. Oil Seal-Output Shaft Bearing Retainer / 3.065" O.D. x 2.12" I.D. x 1/2" thick / Obsolete
FREESE MOTORS in Monticello IA has 2 = 319-465-3541.
KOEHN MOTORS in Wellington KS has 3 = 620-326-5915.
KINSEL L/M in Beaumont TX has 6 = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
B6A-7153-D .. Gasket Set / Obsolete
KINSEL L/M has 1.
HAVEN FORD in Haven KS has 1 = 620-465-2252.
FREESE MOTORS has 4.
MILLER OBSOLETE PARTS in Binghamton NY has 8 = 607-722-5371.
Thanks Numberdummy!!
I took the trans out and noticed that it was NOT leaking around the rear seal on the out put shaft. But it wet all below that and in front.
This thing sat for 41 years, when the gaskets get wet will they swell up and stop leaking or shoud I get the gasket set ant replace??
halaferd
04-02-2014 01:42 AM
Becky_is_a_66
06-09-2013 01:06 AM
cordespc
06-23-2007 04:26 PM
Budman88
10-20-2003 09:38 PM
