need trans seals for F2 - Ford Truck Enthusiasts Forums
Old 09-15-2013, 12:30 PM
1950F2 1950F2 is offline
1950F2 is starting off with a positive reputation.
I have a trans with numbers on side: T87D-1, W.G. DIV SB2
Is it a 3 or 4 speed?? and where can I get seals for it?? Leaks out of both ends. Are they hard to replace??
It is on a F2 1950
Old 09-15-2013, 12:51 PM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
these guys can prob provide you with seals, gaskets. Ford Flathead Engines - VanPelt Sales, LLC
Old 09-15-2013, 04:26 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Need trans seals for F2 with Warner T-87D H/D 3 speed.
Quote:
Where can I get seals for it?? Leaks out of both ends. It is on a F2 1950.
Borg Warner T-87D 3 Speed Heavy Duty Manual Transmission ~ 1948/52 F1/F5 / 1953/66 F250/350.
The following is the only seal in this transmission (see parts catalog pic). Other leaks probably caused by seeping gaskets.
C1TT-4813-C .. Oil Seal-Output Shaft Bearing Retainer / 3.065" O.D. x 2.12" I.D. x 1/2" thick / Obsolete
FREESE MOTORS in Monticello IA has 2 = 319-465-3541.
KOEHN MOTORS in Wellington KS has 3 = 620-326-5915.
KINSEL L/M in Beaumont TX has 6 = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
B6A-7153-D .. Gasket Set / Obsolete
KINSEL L/M has 1.
HAVEN FORD in Haven KS has 1 = 620-465-2252.
FREESE MOTORS has 4.
MILLER OBSOLETE PARTS in Binghamton NY has 8 = 607-722-5371.
Old 09-15-2013, 08:15 PM
Thanks Numberdummy!!
I took the trans out and noticed that it was NOT leaking around the rear seal on the out put shaft. But it wet all below that and in front.
This thing sat for 41 years, when the gaskets get wet will they swell up and stop leaking or shoud I get the gasket set ant replace??
Old 09-16-2013, 07:01 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Replace the gaskets.
1950 ford project abusek Oregon Chapter 7 11-18-2016 08:34 AM
Standard F1 3 Speed Trans Rebuild Parts Cougar54 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-20-2016 04:22 PM
1950 F2 Teardown abusek 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-26-2016 09:43 AM
1950 ford f2 engine conversion Jonkoe 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-02-2016 11:23 PM
please help ford 1950 Engine Swaps 2 09-15-2015 07:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
