Spicer (Dana) 24 Flange (Yoke) Nut - Ford Truck Enthusiasts Forums
Old 09-14-2013, 06:10 PM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
I've started the rebuild of my Dana 24 and it looks like at some point someone may have use the wrong flange nuts. Per the manual, the same nut is used on all 3 shafts (7/8-16, 356148-S) but it looks like the input shaft has a different one and is not a castle nut. I also found a cotter pin in the shaft BEHIND the yoke (flange) that seemed odd.
Any source for this nut, or should they be different?
Any Help?
**** EDIT ****
Never mind..
Found a source for the nuts - www.cj-jeep.com
2.95 each..
Rebuild kit should be here on Monday..
Now I just need a small spring and detent ball...
77 F150 NP 205 transfer case leaks mjr46 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-27-2016 04:29 PM
F 350 pinion seal, u-joint replacement, and differential cover replacement nvrsadi 1999 - 2003 7.3L Power Stroke Diesel 10 05-17-2016 05:19 PM
7.5 inch rear end: u-joint yoke to pinion flange bolt torque spec Dalek Sec Ranger & B-Series 1 11-17-2013 03:59 AM
Most likely a dumb question... Newcomer Offroad & 4x4 61 04-22-2011 10:05 AM
Rear Diff Pinion Seal Replaced...No more leaking MoyockPowerstroke 1999 to 2016 Super Duty 33 11-03-2009 07:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
