rear end differential fluid change
I too need to change my rear diff cover on an '03 F-250 that has spent its life in CT & PA. I am having difficulty finding one in the correct size for the 10 Bolt pattern. The 1999-2005 are supposedly the same rears from what little research I have done so far. If you got your replacement new, where did you get it from and what part number is it (assuming yours is a 10 bolt rear like mine)? Any help leading me in the right direction for an affordable replacement (under $100 - I don't need chrome or any fancy off-road trussing or cooling fins) would be greatly appreciated.
rockauto.com has them for $25 but they wanted $7.50 for shipping. i needed mine right away because mine was leaking so i just paid the extra $4.50 to get it the same day.i dont have the part# off hand but if you go on either website you can put in your year make and model and it will bring up the part for you truck.
I bought Valvoline Synpower 75-140 for the rear differential on my '03 F250. I think you have a different gear ratio from me - mine is the Sterling LS differential. I called the Valvoline folks and asked them whether I needed the additive. They said I needed half the amount called for by Ford as they have LS additive in their product. They said their product does not require additional additives for any other vehicles except Ford does need one bottle.
i got my rear diff cover at auto zone for $37. its just a plain black stock aftermarket cover.
Thanks for your response. Yes, I find the 12 bolt pattern covers fairly easily (and that is what AutoZone and others keep showing as a stock replacement for my make/model/year). But mine only has 10 bolts (none missing) and apparently the common Dana 60 10 bolt cover is too small. That is the only one I have found with 10 bolts in the same shape as what I have. This laying on a gravel driveway trying to work upside down underneath isn't the easiest. I will go over to my friends house and put it up on his lift and try to find the axle tag or get the code off the door sticker just to be sure. Thanks again for the fast response and I am sure I will figure out what I have and where to get a replacement.
To make things a little easier take your spare tire out and it will give you a lot more room under there to work. You might even be able to sit under there with the spare out of there if your not to tall. I'm 6'3" so I couldn't but it still gave me a lot more room to work on it in my driveway. Good luck and when u get the cover let use know what kind of rear u have under there
I just did mine although its a 3.73LS. Use the synthetic rear gear oil the diffs especially on 3/4+ trucks have been known to go out from overheating caused by improper maintenance, or improper break in.
It's rare that Ford requires synthetic so I'd trust them in this case. The front diff is comparatively much cheaper so don't worry if you have a 4x4.
I used valvoline rear gear lube that had additive in it. (Most all synthetics will) I then put it in and drove in circles in various directions (figure eights) and did not hear any chatter. I also did it in 4x4 (in dirt) after the front diff and transfer case and again didn't hear/feel any chatter.
You can put in too much additive and it WILL render the Limited Slip useless. While the debates of LS longevity are ongoing I'd rather not make mine useless by trying to be safe as it still works and mine is a 2003. If you have chattering you will know it and can get some additive at the Ford dealer. I'd add 2oz at a time if you have previously put in fluid with the LS additive in it to make sure you don't go too far.
Futhermore, unless you are a dual rear wheel (I'm not too versed on them) you can get an 08+ rear wheel diff cover from Tousley or other Ford dealers. Its a direct bolt on and is aluminum with fins. Its been reported to be 30* cooler than the non-finned steel one. Mine was rusting so it was no brainer.
You wouldn't ruin your rear end if that's what you are wondering. The main reason Ford requires a synthetic gear lube is because it's supposed to be a lifetime fill. It's supposed to never need changing unless it gets water in it or you have to remove the cover for repairs.
i just looked it up and a rear dana 60 has 10 bolts on the cover. is it possible the rear end was changed in your truck? did you buy it new or used? You might want to look into that. if you bought the truck used and the rear end went on it before you got it its possible the previous owner put a junkyard danna 60 in there because its cheaper. just a thought
I have yet to come across a non synthetic 75-140.
I used Amsoil Severe Gear because that is what a local place I had an account with stocked. I got a couple bottles of the Amsoil slip loc friction modifier also. I did not add modifier for the change. I drove the truck some to check for chatter from the LSD. I got some chatter when loaded so I added some friction modifier.
As for the stock LSD it is just that "limited". The one on my 04' works like it did from new but it does not have near enough "holding power" for my taste. Ford could do much better. I will admit though I am not a fan of clutch style diffs that wear and contaminate the oil as they do.
#29
Rear end oil LS
hey guys i have a quick question. im gonna change the fluid in my 01 f250 rear end. it has 410 gears and a limited slip diff. if i use full synthetic gear oil do i have to add the limited slip additive or just the 75w-140 full synthetic gear oil. thanks in advance for the help
