Tuner recommendations for better MPG ? - Ford Truck Enthusiasts Forums
Old 09-14-2013, 06:56 AM
Steven Stocki Steven Stocki is offline
Steven Stocki is starting off with a positive reputation.
I have a 06 f250 6.0L power stroke diesel. Currently getting 12MPG (city) 15MPG (highway)
Looking to get better MPG and heard a tuner and an intake would be the best route to go.
Looking for recommendations for the tuner and intake from those who've had success with their's.
Thanks.
Old 09-14-2013, 09:07 AM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
An aftermarket air intake is a terrible idea on these engines, the filtering/flow capabilities of the stock setup is second to none and are good to 500 HP. The SCT tuner is the way to go with custom tunes, there are some tune writers that write economy tunes, you can also get a FICM tune for economy.
Old 09-14-2013, 09:15 AM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
I agree 100% with Brett on the use of the factory intake. It is the best for our trucks. I do however believe that to get more power you must burn more fuel and air. There fore in my opinion more power and better mpg's is an oxymoron.
Old 09-14-2013, 05:10 PM
JBSIXGUNS's Avatar
JBSIXGUNS JBSIXGUNS is offline
JBSIXGUNS has a good reputation on FTE.JBSIXGUNS has a good reputation on FTE.JBSIXGUNS has a good reputation on FTE.
Thanks.
Hey bud, is your 6.0 bone stock, bulletproof, or somewhere in the middle? An atlas 40 ficm tune is good for 40horse, there's also an atlas 80 and Hercules tune for your ficm. Sct programer is by far the go to tuner for the 6.0. It won't roast your transmission like those adjust on the fly tuners (stay away from that style) and stick with the stock air filter setup.
Old 09-14-2013, 08:21 PM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is offline
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
I don't know that you can find a tuner or tune that will give you a mileage benefit that would justify the cost of the tuner and tune. Any improvements I have seen are minimal. That's just the nature of the beast with a 6.0 as I can see it. You have to figure, you're powering 8k# of truck down the road.
Your mileage does seem a little low to me, however... Mine gets an average of 16 mpg, mountain and town driving. On the open road, with flat ground, I can get around 18. Towing 12K# I get about 11 mpg. Once, unloaded, I even hit 20mpg on the highway, but that was mostly down hill and a tail wind LOL. Might be something else going on with your truck. But then again they all seem to get their own mileage and that spread is pretty variable it seems. Mostly due to individual driving habits I figure.
Old 09-14-2013, 09:35 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Start with a odb2 gauge, scangauge2 is popular in fte, or the newer smartphone/ios phone/tablets with bluetooth to odb2 adaptor.
The stock gauges are useless at telling you much. You want to ensure you have healthy engine, you might have bad tstat which which will cause over fueling since engine never gets to proper temp. Also a fuel
pressure sender and analog gauge to ensure proper fuel pressure.
Plus monitor the ect vs. Eot delta to determine health of oil cooler.
Imo, ensure things are healthy before spending on tuners.
Old 09-14-2013, 10:46 PM
POORBOY1964's Avatar
POORBOY1964 POORBOY1964 is offline
POORBOY1964 has a good reputation on FTE.POORBOY1964 has a good reputation on FTE.
Very well said ^^^^ The mileage does seam a little low get a monitor if you don't already and see if everything is really healthy
Old 09-15-2013, 08:41 AM
Per4mance's Avatar
Per4mance Per4mance is online now
Per4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to all
I run the street tune that came with my SCT Livewire, I don't run my truck hard and don't go over 75 on the highways but I get get up to 21.5 mpg with it but I draft the semi a lot ........... and that's hand calulated
Old 09-15-2013, 10:22 AM
Nixoninc's Avatar
Nixoninc Nixoninc is offline
Nixoninc is starting off with a positive reputation.
When I first bought the truck in my signature, I was unimpressed by the fuel economy. I eventually figured out that the engine coolant temp was not going above 140 degrees because the thermostat was stuck open. After replacing the thermostat, my mileage improved and noticed a small improvement in power too.
Old 09-15-2013, 11:49 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Overall the best MPG is running stock IMHO.
I get the best economy running stock on the highway. I do see an improvement in MPG using a couple different tunes for straight city driving (likely from faster turbo spool etc), but the highway MPG takes a dip.
12 City and 15 highway is pretty bad, unless that is with the latest strategy flash.
Josh
Old 09-15-2013, 12:11 PM
droffan droffan is offline
droffan is starting off with a positive reputation.
202,000
60 mph in the geezer lane, 19.8 mpg
Old 09-15-2013, 12:13 PM
Quote:
Josh
When I had all of the work done on my truck recently, I had the latest flash installed as well. Was this a mistake?
Old 09-15-2013, 12:39 PM
Bullitt390's Avatar
The latest flash is good for cold starts, etc but sucks for MPG.
Either way, 15 mpg highway is pretty bad unless you're talking 15 mpg @ 85 mph
Josh
Old 09-15-2013, 01:16 PM
69cj's Avatar
My 05 is a 4X2 and gets 12 to 15 around town and 17 to a high of 21 highway. Towing the 31' 5er it's 11 to 13 highway. I agree with getting gauges to see what is going on with your engine. If you have a 4X4 it will be less but by how much I have no clue. Incidentally, if you do a lot of short trips where the engine doesn't come up to full heat soaked temps, and not by the factory gages, there's a good chance you'll never get out of the single digit range. Diesels use heat and compression to get their economy. A cold running engine will never be economical unless it's being driven over a cliff.
Old 09-15-2013, 08:36 PM
I appreciate the responses.
Looks like some of this stuff is over my head.
Anyone near Boston or southern NH that I can pay to help fix the problem ?
Thanks.
86 f250 460 tuner? 1986-460 Computer Chips & Tuners 6 09-14-2015 04:51 PM
Best Economy Tune out there Tore 6.0L Power Stroke Diesel 6 02-05-2013 02:51 AM
V-8 gas MPG improvement? Apocalypse Excursion - King of SUVs 41 11-25-2012 03:32 PM
Whats The Best Kind Of Tuner For A 1996 F350? CountryGirl3294 1994.5 - 1997 7.3L Power Stroke Diesel 39 06-27-2011 10:39 AM
Intake Manifold, is it worth it to upgrade? lakewood 6.0L Power Stroke Diesel 45 12-12-2009 08:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
