1967 F100- 1956 F100 - Ford Truck Enthusiasts Forums
Old 09-14-2013, 07:25 AM
1956in1956's Avatar
1956in1956 1956in1956 is offline
1956in1956 is starting off with a positive reputation.
Where the manual transmissions the same in a 1967 F100 with a 360 as the 1956 F100 with a manual tranmission V8
Old 09-14-2013, 10:26 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Probably not. If you had the T98 granny gear four speed, then yes. Otherwise no.
That said, there is a good chance that you can bolt a transmission from a 67 F100 into a 56 F100. My memory of the manual transmissions available for 67 1/2 tons were:
1 - 303 sychronized three speed with dual bolt pattern front flange
2 - T85 / R11 overdrive three speed with dual bolt pattern front flange
3 - the above mentioned T98 heavy duty four speed.
I think the inner bolt pattern on the dual pattern transmissions is the same as the bolt pattern on the original column shift three speed transmissions for 56. Drive shaft modifications would be required depending on what transmission you end up using.
Production dates for 1956 F100 nassi 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-25-2015 08:12 PM
1954 F100 Heater Box medicpg 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-04-2014 01:31 PM
1956 F-100 dashboard F100 AMG WTB - Parts & other 2 08-31-2014 11:29 AM
1955- 1956 frame 1956in1956 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-18-2013 01:19 PM
1956 F100- 1956 Mercury 100 1956in1956 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-15-2013 12:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
