Engine Swap Questions
on
Is your '95 truck mass air? If so you would have to change the cam in the '90 as it has a different firing order and won't work with the sequential injection in your truck. Assuming the '90 is a truck motor it is a direct bolt-in for the most part besides that as long as you don't try to use any wiring that comes with the donor motor.
I plan on using the harness thats in my truck at the moment.
So it should be a direct bolt in?
jb7679
03-22-2014 02:47 PM
snowmobiler7c
18
04-15-2009 08:54 AM
03stang
01-13-2004 01:53 PM
fiveliter8
05-22-2002 07:14 PM
