Modular V10 (6.8l)
Starter bolt size
Old 09-14-2013, 01:09 AM
shore's Avatar
shore
shore is offline
Starter bolt size
What size are the starter bolts on the 02 v10. Going to change the starter on my SD this weekend and the starter bolts are pretty crusty. Time for new ones. Hope they don't break off in the bell housing.
Old 09-14-2013, 09:36 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Try a 3/8" 10mm impact socket. It's six-sided and won't flex at all rounding off the bolt head. Use extensions as needed to put the ratchet where you can get it to turn.
Soak everything down with PB Blaster and give it time to work.
Remove right front wheel for much better access to the upper hidden bolt.
Cross your fingers that you don't shear any off. They aren't very large diameter bolts.
Old 09-27-2013, 07:29 PM
buddharacing's Avatar
buddharacing
buddharacing is offline
I cracked a craftsman socket taking mine off.
Old 09-27-2013, 08:03 PM
shore's Avatar
shore
shore is offline
My starter bolts were really tight also. Except for middle bolt. I had a local shop put my last starter in and they stripped the aluminum threads out of the bell housing hole. That bolt came out pretty easy. the head on the top was almost completely rounded off, and super tight. it took me 3 hours to get the old stater out and the new one put back in. wheeeeew glad that projects over with.
dvrjump
06-20-2014 06:15 PM
wulfman
06-25-2013 05:15 AM
Flyinstroke
06-05-2012 11:04 PM
radmacks
09-11-2011 05:40 PM
brooklyn
02-05-2010 08:57 PM
Quick Reply: Starter bolt size
