Starter bolt size - Ford Truck Enthusiasts Forums
Starter bolt size
Old 09-14-2013, 01:09 AM
shore shore is offline
shore is starting off with a positive reputation.
Starter bolt size
What size are the starter bolts on the 02 v10. Going to change the starter on my SD this weekend and the starter bolts are pretty crusty. Time for new ones. Hope they don't break off in the bell housing.
Old 09-14-2013, 09:36 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Try a 3/8" 10mm impact socket. It's six-sided and won't flex at all rounding off the bolt head. Use extensions as needed to put the ratchet where you can get it to turn.
Soak everything down with PB Blaster and give it time to work.
Remove right front wheel for much better access to the upper hidden bolt.
Cross your fingers that you don't shear any off. They aren't very large diameter bolts.
Old 09-27-2013, 07:29 PM
buddharacing buddharacing is offline
buddharacing is starting off with a positive reputation.
I cracked a craftsman socket taking mine off.
Old 09-27-2013, 08:03 PM
My starter bolts were really tight also. Except for middle bolt. I had a local shop put my last starter in and they stripped the aluminum threads out of the bell housing hole. That bolt came out pretty easy. the head on the top was almost completely rounded off, and super tight. it took me 3 hours to get the old stater out and the new one put back in. wheeeeew glad that projects over with.
Starter bolt size Badboy4wd 1999 - 2003 7.3L Power Stroke Diesel 12 10-16-2016 11:16 AM
Starter bolt size, 70 f-100 390 engine 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-11-2013 10:00 PM
Starter mount bolt size?? Help flamesoldier 1957 - 1960 F100 & Larger F-Series Trucks 1 01-07-2013 04:48 PM
Need hood bolt and starter bolt sizes please :) BORDERBUM 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-07-2011 08:54 AM
starter bolt size? ETHEL 1987 - 1996 F150 & Larger F-Series Trucks 1 04-25-2007 11:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
