1979 ford f-250 camper special - Ford Truck Enthusiasts Forums
Old 09-13-2013, 01:09 PM
grizz1979 grizz1979 is offline
grizz1979 is starting off with a positive reputation.
How in the heck do i change the fan in the fan box?? What would be the easiest way? The fan was going out for about 3 months makin a grinding sound then all of a sudden one day it made a loud pop!! and now nothing works. I checked the fuse and its good. I need to put the new fan in anyway before winter gets here
also the truck does have air conditioning. I also have another problem. when i try to start my truck it goes to crank but instead acts like the battery is dead. And slowly starts to crank and the only way i can get it to shut off is to pull the posative battery cable off. The key wont even turn it off. i have changed the starter and battery and solenoid twice. also it does work for a couple weeks then ill go to start it and the battery will be totaly dead?? and if its not it will just slowly slowly crank over and over again. Please help. Been trying to get this running since i got out of the Army. and im going crazy!!
U.S Army Infantry 11B thanks in advance
400 motor
3/4 ton full time all wheel drive with no locking hubs. just when i need 4 wheel i put it in lock in the cab
91 F250 Ignition 7.3L conundrum envirees 1987 - 1996 F150 & Larger F-Series Trucks 6 03-07-2017 08:37 AM
Help diagnosing amp draw - smoked alternator and both batteries dda140 1999 to 2016 Super Duty 3 11-25-2014 09:54 AM
1979 F-150 4WD updates jtrux 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-28-2014 09:41 PM
Alternator Only Charges Full Battery - Stumped lign Excursion - King of SUVs 29 10-19-2013 01:37 PM
What pressure does the A/C system begin to blow-off/vent? jtharvey 1999 - 2003 7.3L Power Stroke Diesel 9 08-04-2008 09:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
