Why does my single tank 88 F150 have a tank selector valve?
Old 09-13-2013, 07:47 AM
rderr's Avatar
rderr
rderr is offline
My truck seems to be starving for fuel. Replaced the inline filter and still have the issue. Before I drop the tank to replace the sending unit I noticed the fuel selector valve. Could this be clogged and restricting fuel? Also why would an all original single tank truck even have a selector valve?
Thanks Rick
Old 09-13-2013, 08:59 AM
cbrown9064's Avatar
cbrown9064
cbrown9064 is offline
Are you talking about the "module looking thing" on the frame rail? I think that's called a Single Fuel Reservoir and is used to control fuel flow back from the fuel rail. Excess fuel not needed needs to get back in the system and this reservoir is part of that process.
Old 09-13-2013, 09:15 AM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
It's a fuel reservoir and holds about a pint of fuel for the HP pump to draw from. This was fords solution to EFI without tank baffles. In 90 they redesigned the system and had an insert that went into the tank to function as a baffle. That's also when they went to a single in tank pump.
From what I understand only the 85-86 versions had a filter in them and yes, that can choke off fuel.
You could have a bad in tank pump and the HP is doing all the work. I had an issue like that where it would cut out over 2500 rpms.
Old 09-13-2013, 12:04 PM
rderr's Avatar
rderr
rderr is offline
Thanks guys. I am guessing I will be pulling the in tank pump next. Any tip or tricks before I begin? I've done thin on other vehicles in the past but not this particular one.
Rick
Ex-ChevyOwner
10-07-2015 09:14 PM
PintoGuy
06-12-2015 10:41 AM
BigRedDooly96
05-19-2014 08:57 AM
scorpionmarine
12-09-2006 09:43 AM
my93
01-08-2005 12:32 AM
Quick Reply: Why does my single tank 88 F150 have a tank selector valve?
