Put the 6.2 to the test today
Denny
I put my 6.2 to the test on Monday. I picked up a Raptor 367SE Toy hauler;
and brought it home about 190 miles. I had a steady 20 mph side wind, and also went through a freaky storm with gusting winds for about 30 miles where I had to slow to about 45-50 mph; not short of power, but the wind was pushing me around quite a bit. The 6.2 performed flawlessly! I am not a "gas mileage freak" but estimate around 6.5 to 7 mpg while pulling it in the wind.
Probably will get somewhere around the 8 mpg mark when not in the goofy winds.
All I have to do is to think back to when the 460/C6 or 390/ 4 speed manual was the best option we had for pulling the big loads!! We've come a long way, baby!
We are in Hurricane UT trying to figure out our plans from here with all the gov parks closed but we are at 2K ft and I have to tell you this truck has come alive in a big way. It turned over 5K today with 550 of that not towing so I'm guessing it may be getting broke in.
Denny
Denny
Other wise glad you are enjoying the nice ride. Sounds like some fun you are having.
Hurricane, Utah I have been there before. You must be near Zion National Park. Beautiful place when it's open. My wife and I did a quick day trip there when were in Las Vegas in 2005. Around the same time to boot.
This part of the country has beautiful scenery buy I think we will be heading a warmer climate.
Denny
So far it's around 8 with a lot of heavy grades and high altitudes. We are in Williams AZ now for a couple of days and I think most of our big grades are behind us, we even have full hookups for only the second time in the last month. I think I have the truck figured out and will post later how I have been driving it, to much happy hour today.
Denny
Denny
Denny, I am glad to hear about how your truck is pulling the RV. I just ordered my new 6.2L 2014 SD F350 yesterday and still a little nervous about the switch from my 6.0L to the 6.2L. Just not sure how the truck will tow my 12K RV, but it sounds like it will do ok after reading where you have been to. We were in the same areas traveling in 2005. Absolutely loved Bryce Canyon, the colors of the HooDoo's where just amazing.
Anyway, thanks for the updates on your travels and how the truck is doing towing in elevations.
Too bad the parks are closed but enjoy the ride.
Denny
The one major adjustment you will have is the rpm coming from a diesel, coming from a V10 I had to get used to different noise at the higher rpms the 6.2 makes, it sounds more like a muscle car. What worked the best for me pulling grades was using the manual mode and keeping the rpms between 3200 - 4200. I can tell you from my experience on the this trip the 6.2 with the 6 speed in manual mode brings the fun and control back into towing. When you get your truck give it a little time to brake in before you make any judgment on the 6.2 capabilities.
Denny
Denny
Manual Mode is definitely the way to go with the truck while towing. I mentioned it in my trip report. My truck did fine with fifth and sixth while towing to SC on 3.73s. Tow Haul mode is where the let down for me was located.
Our next long trip to my knowledge will not be until Oct 2014. We will be heading to Disney World's Fort Wilderness. All our other trips will be within 3 hours of home.
BTW, I just turned over 65,000 miles
The only time I use the tow haul is when I'm coming into a town, I shift it into drive and take advantage the TH down shifting until we clear traffic and then either turn it off or go back to manual. I think the TH mode waits to long to shift making the truck feel like it's ran out of power when all it needs is to shift.
Denny
Denny
#28
Manual works great on the interstate. TH for stop and go.
#29
#30
It also takes a long time in TH to upshift even after you come out of the throttle and are going a steady speed.
