Question about HPOP testing
I just replaced HPOP and LPOP . Did air test through ICP , when IPR is powered there is a small amount of air coming from the dump hole on the rear of the HPOP. IPR is new ford, HPOP is ford. Test was done dry ( pump just out of box )
You can put finger over hole and hold air back for a sec or 2 ( just to give a idea of how much air was there ).
Truck is back on the road running fine, just wanted to see if that was normal or do I need to pull it out and try again
Wenuck72
07-29-2010 07:25 AM
mastrianni_84_250
11-03-2002 05:10 PM
