292 Y Block - Engine Lifting Points
As the title implies; I'm considering pulling the engine in my 63 4x4. Nothing wrong with it, but since I have it down to the frame and engine, if I pull the engine I can get the entire frame taken care of and perhaps clean up and paint the engine.
I've pulled other engines by removing the carb and using a lifting plate in it's place. I'm not sure how that would work with the Y block as the intake manifold looks a bit different (perhaps that's just me)
So - Where is the best place to attach the hoist to the engine? I figure I'll drop the transmission before pulling the lump (easy access with no cab..)
Thoughts / Advice?
Thoughts / Advice?
So you replaced the bolts holding the intake to the head with longer ones and attached the chain to those?
I don't want to remove anything from the engine if I can help it; I just want to lift it out temporarily to paint the frame and maybe the engine.
I suppose I could do all this without pulling the engine, but since access is so easy now..
In terms of the tranny, thats what a tranny jack is for...
(also works for the transfer case...)
I've used axle straps through the exhaust manifolds.
2''x36'' Car Tie Down Axle Strap w/ Wear Pad - $8.95 : Transport Chains | Load Binders | Ratchet Straps | Winch Straps
Jrock909
04-09-2007 09:24 PM
DarkWolf40
16
01-12-2004 08:02 PM
ZombieSlayer
04-02-2003 11:30 PM
slojason
03-17-2003 06:57 PM
