Cancer Cure?
It would depend on were you live. My 86 F250 (pretty much same bed design) showed rust in paint chip areas in the rear fenderwells. Well I owned that truck for about 14 years & they got a little worse but never rusted through. I lived in Northern Nevada where we got some snow & salted roads. But it is an older truck. Unless you plan to make a show truck I wouldn't waste any time on it. My engine bay is the cleanest neatest area on my truck. Because that is the heart.
Thanks for all the input fellas. Looks like I may just hold off for a while treating her for a while. I bought it in Kansas where they get a good bit more snow than down here in Oklahoma, so hopefully it won't spread too fast. I think when I finally do decide to patch her up I'll have it done at a body shop and have those seams filled in with something. I would like to have the whole underbody and frame coated at some point as well. I'll post some pics to my profile this weekend at some point to show her off a bit, she's a real beauty.
Just because anything is done professionally doesn't mean it is done properly or correctly. Just sayin.
Here's a good read.
Perfect Paint Job
Here's a good read.
Perfect Paint Job
Correct, he is just blowing hot air, like most of his posts. Nothing to add other than his 15 yr old OPINION
Typically trucks/cars/machinery do not rust from the outside in. The rust starts from the BACK. When you see it, is is to late. The shiniest paint in the world doesn't help stop rust
As Brad mentioned, that rust on the wheel arches started from the inside and is working its way out, because of the design of the inner wheelhouse of our trucks. There's three options for that at this point: replace with a rust free bed, replace bedsides, or cut out the rust and weld in a patch panel. Whichever way you decide to go, you're going to want to remove the inner wheelhouse, and go to town on the inside of the bed panel with some rust preventive measures. POR 15, or something similar to it, would probably be best. Before you reinstall the wheelhouse, hole saw some holes in it near the wheel arch area, so that you can get in there and hose it out, and also so it's able to drain and not trap junk in there that'll cause more rot. 100% of the time, when you read about less than stellar results with patch panels on a wheel arch, it's because the inner wheelhouse wasn't dealt with properly, and the backside of the panel wasn't treated properly.
For the cab area, you should be able to find patch panels that can be welded in.
johnson.jeff.a
18
08-02-2014 04:47 PM
