I need a trailer hitch
Old 09-11-2013, 09:01 PM
bra$$monkey's Avatar
bra$$monkey
bra$$monkey is offline
Anyone know where I can order a reese trailer hitch for my 56?
Old 09-11-2013, 11:46 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
A lot of the of the frames for years have been the same width so you should be able to get one from just about ant 70's-80's Ford and it would work. I used to know exactly but I don't recall. Sorry.
Old 09-12-2013, 09:25 AM
flattie39's Avatar
flattie39
flattie39 is offline
Hey Bra$$ - I just took one off my 54 that the PO had installed. It's complete with the round plug and in good shape. Where are you located? The shipping may be costly. Ken
Old 09-12-2013, 11:14 AM
AXracer's Avatar
AXracer
AXracer is offline
I used a Drawtite #40050 fit like it was made for it. If you must have a Reese, try crossmatching the drawtite #. I got mine from etrailer.com.
Old 09-12-2013, 06:04 PM
bra$$monkey
$250 - oof
I guess I should have known it would be expensive.
Old 09-12-2013, 08:35 PM
AXracer's Avatar
AXracer
AXracer is offline
It depends on how heavy a trailer you are planning on towing. If you are going to tow a lighter trailer you can use a lower grade cheaper hitch. I set mine up to tow a 7500# enclosed car trailer so I used a class IV hitch rated to 10,000#.
Class II up to 3500# and class III up to 5000# are cheaper. If you want to go with a lighter class hitch you can look up my hitch model on drawtite and see the application, then look up the lighter class hitch for that application.
Old 09-12-2013, 08:50 PM
bra$$monkey
I have a 5 x 12 utility that weighs maybe 900lbs empty. Most I would ever tow would be maybe 3500 lbs. & I can't think when I would need that much. Mostly I use it for lumber or bicycles.
Old 09-12-2013, 09:40 PM
AXracer's Avatar
AXracer
AXracer is offline
Then go with a class II hitch, will be a lot cheaper.
Old 09-12-2013, 09:43 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Frame widths are the same up to '72.....after that they are wider.
Old 09-13-2013, 07:10 AM
jniolon's Avatar
jniolon
jniolon is online now
old and in the way
here's what I used from Early Classics...
Early Classic - Catalog
john
Old 10-02-2013, 07:23 PM
smallello's Avatar
smallello
smallello is offline
You can probably pick one up at the next swap meet for a lot less. What part of AZ are you in?
Old 10-02-2013, 09:16 PM
jniolon's Avatar
jniolon
old and in the way
Lillith
12-06-2018 11:34 AM
93calypsohatch
08-24-2014 09:24 PM
X_Hemi_Guy
Ford Truck Parts for Sale
09-11-2012 09:25 PM
Missouri Mule
2004 - 2008 F150
02-10-2005 12:48 AM
HardScrabble
09-20-2004 06:32 PM
Quick Reply: I need a trailer hitch
