Ignition Switch Options - Ford Truck Enthusiasts Forums
Old 09-11-2013, 08:47 PM
tjdad62's Avatar
tjdad62 tjdad62 is offline
tjdad62 is gaining momentum as a positive member of FTE.
Guys and Gals,
I am beginning the wiring portion of my 1950 F-3 project. I will be using a push button start using a 2 pole start button. My question is, what kind of ignition switch did you guys use? I have the original dash mount switch, but it has no keys and looks like the previous owner may have used a flat head screwdriver to start it with. I want to keep a dash mount to maintain the original look and feel. I was thinking that a dash mount switch from a late 60s early 70s would be the ticket. Not opposed to enlarging the original dash hole to accommodate the newer switch.
Any help is much appreciated.
Randy
Old 09-11-2013, 09:27 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
I bought what I'm sure is a "replica" of the original ignition switch. The PO of my truck had removed the original and replaced it with a 2 pole toggle switch.
Here's the right one for your '50 from Mac's:
6A-11572-B
Ford Pickup Truck Ignition Switch - F1 Thru F8
1948-1950 Ford Pickup Truck Ignition Switch - F1 Thru F8 - MAC's Antique Auto Parts
Hope that helps.
Old 09-11-2013, 09:34 PM
Just another Joe
You'll also need the cylinder and keys that fit that switch housing.
That's from Mac's also. 8A-11582-A
Ford Pickup Truck Ignition Switch Cylinder & Key Assembly - Has 49-50 Style Keys - F1 Thru F8
And you'll need the bezel to hold the switch into the dash.
Also from Mac's. 0A-11580
Ford Pickup Truck Ignition Switch Bezel - Stainless Steel - 1-1/8" OD - 3/8" ID
Old 09-11-2013, 09:37 PM
Just another Joe
Quote:
Originally Posted by tjdad62 View Post
Guys and Gals,
Randy
So, you probably just need the cylinder and keys.
Old 09-11-2013, 10:04 PM
tjdad62's Avatar
Thanks Jolly...after pricing that stuff I will try the local wrecking yard since a switch there runs about $7 including the bezel. I might have to get a replacement cylinder if it doesn't have the key.
Old 09-12-2013, 12:34 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Napa has a good selection of key switches (and push buttons). I did buy an on-off key switch there for another project. It would work fine, but it doesn't keep the keys looking like the original Ford keys.
Dan
Old 09-12-2013, 04:58 AM
HBN's Avatar
HBN HBN is offline
HBN is starting off with a positive reputation.
My truck had the original switch, but no key. A local locksmith was able to make a key for it.
Dave
Old 12-29-2013, 03:16 PM
Tilleyman's Avatar
Tilleyman Tilleyman is offline
Tilleyman is gaining momentum as a positive member of FTE.
my ignition switch works with a small screwdriver, and I'd like to put in a new cylinder so I'd have keys, but I can't seem to get the old one out of the switch. Any tips?
Old 12-29-2013, 04:11 PM
pineconeford's Avatar
pineconeford pineconeford is offline
pineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to behold
Quote:
Dave
You have more talented locksmiths than around here. I took my old switch to one (he has been in the area for 30 years) to have a key made and he just looked at it and said it wasn't worth his time. Nice, huh?
So I took a three-position switch from a box of parts I had and used that instead. I have a push-button start and am looking forward to seeing someone try and start the truck using just the key. My starter button is red, same color as the dash and if you don't know what it is for.....well the entertainment begins.
Cruise night parking lot - summer 2014
"Can I drive it?"
"Sure, take the truck for a spin - the key is in it!!"
....futz, futz, futz.....
"What's the matter?"
"It won't start."
"Did you turn the key?"
"Yep, doesn't do anything."
"That ain't the starter"
"A little help here?"
"Well, and you have to double-clutch it" (just to add more confusion)
"Huh - does that mean the clutch has to be all the way in before it will start?"
No, it just means that once it's running, you need to double clutch to change gears, they aren't synchonized. And throw that lever on the floor forward - it's the parking brake"
"Uh, OK...but how do I start it?"
"No, that's the high beam switch. Nope, that's the wiper ****. Yep, you're getting there, you'll need to use that choke **** to start it."
"All the way out - and this lever forward?"
"Yep"
"Still won't start when I turn the key"
"Push that button right there"
"Whoa! - jeezum, what did I do!?"
"You gotta have it in neutral or your foot on the clutch when you push that button"
"I give up"
My cunning plan.
Dash Mounted Horn Button fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-31-2016 01:17 AM
Fuel Selector Switch removal texasblue55 1967 - 1972 F-100 & Larger F-Series Trucks 5 01-29-2016 02:08 PM
The project begins, 12 Volt Conversion & Rewire Vegas123 1948 - 1956 F1, F100 & Larger F-Series Trucks 78 12-07-2015 01:37 PM
binding cylinder inside ignition switch Becky_is_a_66 1961 - 1966 F-100 & Larger F-Series Trucks 19 07-11-2014 04:20 PM
HOW MANY HOLES IN DASH? mrfox0246 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-31-2014 08:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
