'56 LS/LQ4 SWAP-HEADER QUESTION
G uys,
Have installed 2003 LS/LQ4 in our '56. What has anyone used for headers other than the original cast headers. Tried "shorty style" , clearance problem with under floor brake booster and steering . We're looking at "hugger style". Any help, photos, recommendations would be greatly appreciated.
Looking forward to your photos.
Hi Bob,
I know you specifically stated headers here..... But valuable info may surface for others, so I will share what I've learned / experienced.
In talking to Ken Wolkens (LS harness / conversion specialist), he suggested Corvette C6 LS3 manifolds worked on his jeep, which had 28" between the frame rails. My '51 has 27 1/4" between the rails. He said I should have 1" to spare on each side.
I will mock up my engine / trans / exhaust soon. Just today received my 6L80e back from conversion to 2WD.
*I anticipate some head scratching.*
I did buy the C6 / LS3 manifolds from ebay and should arrive soon. I also run the factory booster and brake master.
I just removed a 390 with C-6 that had headers installed. That cleared my steering shaft (barely) and had absolutely no issues with the brake master / booster.
Any chance you can reposition the engine a bit on the mounts for more clearance? Or offset to one side just a bit?
My setup may be somewhat unique. I have an old heidt's crossmember and mustang II independent suspension upfront.
Ken also mentioned trying the Cadillac CTS-V manifolds, which fit tight to the block, but with more of a rear exit. Maybe they make a bolt-in header for that application that would work?
Hope this helps someone and we can answer Bob's questions.
Doug
Doug
Hey Bob,
Here's an article about installing CTS-V headers with many pictures. They show some pretty tight quarters, including working around the steering shaft.
2009 Cadilliac Cts V Bolt Ons Fitting Tubes Photo 23
Maybe it'd be worth trying those headers?
Here's one picture: http://www.gmhightechperformance.com.../photo_26.html
And another where you can see the tight spacing between head, steering shaft and engine bay wall: http://www.gmhightechperformance.com.../photo_18.html
Doug
Doug
Hey Bob,
Here's one picture: 2009 Cadilliac Cts V Bolt Ons Underside Photo 26
And another where you can see the tight spacing between head, steering shaft and engine bay wall: http://www.gmhightechperformance.com...s/photo_18.htm
Doug
Doug
Hey Bob,
And another where you can see the tight spacing between head, steering shaft and engine bay wall: 2009 Cadilliac Cts V Bolt Ons Oil Filter Photo 18
Doug
Doug
Hi Bob,
Did you make some headway here?
I will receive my Corvette C6 manifolds tomorrow to trial fit. I bought the LS motor mounts from Scottshotrods.com http://www.scottshotrods.com/Images/...r-mount_LG.jpg .
Justin, the owner there didn't know if the C6 manifolds would clear his mounts. He said he always uses headers.
cheers,
Doug
cheers,
Doug
LS HEADERS
Doug,
After talking with TECH guys @ Sanderson, Holley, Hedman and Speedway's staff, I believe these are for our LS/LQ4 6.0L engine, if it is not we are going to be very upset not to mention the added expense along with time.
We'll send a note along with photos once there are installed.
Brake Booster Installed, Brake Pedal Clearance looks ok right now, steering not so sure. Can't wait for those headers !!
Don't know exactly Bob's final configuration. However on my '51, I used C6 Corvette (LS3) manifolds. They are very narrow and just barely fit between my frame rails. I found them on ebay for about $100 shipped. I then had them ceramic coated maybe for another $100.
I used the stock heat shields and extended it on one side to sit between the motor mount and the manifold.
In stock form, these are good for 480 HP, so I figured they'd be fine for me. (my engine is 6.2L 403HP - L92.
You can buy the flanges to build your exhaust from ebay. Forget the guy's name. About $50 for 1/2" thick flanges. I bought those. Then run the OEM LS3 gasket and you'll have no leaks.
One more note, I'm pretty sure my '51 frame is narrower than next generation. If I remember properly, 27" in between upfront.
Doug
Doug
