fuel pressure gauge - Ford Truck Enthusiasts Forums
fuel pressure gauge
Old 09-11-2013, 09:46 AM
ihandy ihandy is offline
ihandy is starting off with a positive reputation.
fuel pressure gauge
where can I get the fitting for testing fuel pressure
Old 09-11-2013, 09:47 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
A hydraulic shop. The fitting is 1/8 NPT x M12 x 1.5
Old 09-11-2013, 02:17 PM
GSlahor GSlahor is offline
GSlahor is starting off with a positive reputation.
I got mine from Diesel Manor, along with the fuel pressure gauge.
By the Way........ what's the correct fuel pressure I should be seeing with the blue spring upgrade ?
My gauge sits very steady on 65psi............. is this correct ?
TIA.............
Old 09-11-2013, 03:46 PM
POORBOY1964's Avatar
POORBOY1964 POORBOY1964 is offline
POORBOY1964 has a good reputation on FTE.POORBOY1964 has a good reputation on FTE.
Quote:
If you want to order on online Glowshift sells the adapter only, but as posted above any tubing or hose shop should be able to hook you up
TIA.............
That is a good psi,, over 50 but under 70
Old 09-11-2013, 03:54 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is online now
MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.
ihandy....check out ITP (think they're merged with MKM Customs/Sinister)...they have a nice line with a schrader valve.
GSlahor....I read a steady 65psi...sometime it sits at 67.
Old 09-14-2013, 07:37 PM
I took the old plug left over from the blue spring upgrade drilled out the center then brazed on an air fitting so I could attach a hose with a guage to check the pressure worked great
fass fuel pressure farmer ford 6.0L Power Stroke Diesel 3 04-17-2014 11:20 AM
1999 7.3 fuel pressure regulator jsavin 1999 to 2016 Super Duty 8 02-26-2013 09:26 PM
what shoud fuel pressure be for a 88 bronco gary666 1978 - 1996 Big Bronco 7 04-06-2012 12:58 AM
Fuel Pressure issue???? GreaseMonky 1994.5 - 1997 7.3L Power Stroke Diesel 26 02-28-2011 08:49 PM
Fuel Pressure Tester homesteader 1999 - 2003 7.3L Power Stroke Diesel 7 11-29-2010 10:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
