waytallwhitey's engine pull pics
Daisy and I are in upstate NY at John's place pulling the engine out of Frank's (waytallwhitey) truck for an oil pan and stuff. I'll post more later - already stayed up tooo late visiting with John.... Here's a couple pics for ya though!!
What it used to look like:
Still pretty good here:
Uh oh...
Does anybody know how to put one of these back together?? I hope Frank has good insurance.
Uh oh...
Today, engine and engine bay will get cleaned and painted, then we'll flip engine over for oil pan replacement.
Oh yeah, looks like we are gonna need a new CAC. This may explain max of 10psi boost (truck is ALL stock):
Low ceiling in the shop... You know how I roll - I make it work with what I have!! At least I'm not on the side of the road - remember Alex in AK??
I'm having a BLAST so far. As rusty as this thing is, everything has been easy so far. Toooo easy. This place is beautiful - even though it is unseasonably WARM - I'm enjoying time with friends and getting to give Frank his truck the kind of love it can't get at the 'mechanic'. He will be PROUD of this thing when he sees it next!!
Well, for some reason everything up here RUSTS AWAY eventually. The oil pans take a beating because they get sandblasted with road salt and gravel, coated in mud and then heated/cooled on a regular basis. Once the thin factory powder coat is compromised - the end has begun.
The new pan has truck bedliner coating on it and I bet the owner becomes more attentive to keeping it clean and touching up the paint as needed.
And wouldn't ya freakin' know it is HOT and HUMID up here right now!!!! It's much cooler at my house. I'm drinking a gallon of water a day and still melting. Not at all what I expected!
I don't mind fixing one up 'stock'. There is something to be said for how smooth and quiet a stock truck is. Its always nice to hear something run RIGHT. It also helps if it LOOKS GOOD!! Dunno if it'll run right yet - but it WILL look good!
Engine got p-washed today to remove rust scale and finish degreasing it, then hauled back into the shop and placed on the engine stand. The truck was drug out and the engine bay descaled and degreased as well.
Up-pipe to manifold bolts were rusted to paper-thin and were NEVER coming out, so we decided to remove the exhaust manifolds. ONE bolt came out with a wrench... The rest came out with help from our friends oxygen and acetylene. The bolts all came out of heads pretty easily, but a couple required some thermal persuasion from the MAP gas torch. We decided we'd at least try to extract the bolts from the manifolds. I'll be damned if we didn't get them all out!!! Unbelievable - seriously....
I am more of a believer in Kroil than ever!! Every bolt I thought I might be removing got hosed down the minute I saw the truck, and I sprayed them all again a few times for good measure. Its miracle stuff.
The new oil pan got bedliner applied and I really wanted to install it today, but we are still waiting for sealant, dipstick thingy, etc. We did get new SS fuel lines and some other goodies from www.veggiegarage.com and a box from Riffraff.
Tomorrow we'll rebuild the turbo and pedestal, paint the engine, paint the engine bay, (source a new CAC?), install new GP's and hopefully get the parts to rebuild oil cooler and re-install the oil pan...
