Door striker plate and locking mechanism's
Without knowing what your working on all I can tell you is what I'm looking at putting in my 49 F1 is a Altman Latch
They increase the saftey quite much.
do a search on youtube and you can see how could it can turn out.
There are a couple of types of Altman latch that will work on your truck...the original design was more universal and was not a direct replacement for the OEM door handle. They have since refined the design and now you can use the Altman latch along with the stock outer handle without any further modification. As for the "window stuff" there is no issue here.
There are two ways to go with the Altman install in the door...one is to use the plate and screw it over the cutout area on the door and the other is to use the plate and weld it into the door. The second is my preference since it makes such a clean job but some prefer the first, especially if the truck is already painted and they don't want to weld on it. If you are going to go the Altman route then decide ahead of time which way you are going to go...if you are going to weld the plate in place then don't waste your $$$ on the stainless plate, get the plain steel version.
dwaynewoodman
12-06-2004 10:23 PM
