Lessons Learned On HPOP & Fuel Bowl Rebuild - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-10-2013, 09:45 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Well after 10 years I got the dreaded oil leak. After some simple green cleaning and some strategically placed towels in the valley I pinpointed the leak to somewhere under the fuel bowl.It was definitely oil and not diesel fuel and if you have to take everything apart you might as well replace all the O-rings. No problem I called Diesel O-rings and ordered all the O-Rings for the fuel bowl and HPOP and the also the non serviceable plug for the HPOP. I started the job early Friday morning and everything was going smoothly until I got to the bolts holding the HPOP. Now the lesson I learned was never, never, never use a 12 point socket on any bolts because if you do it will round the head right off of one of the bolts that hold the HPOP in. . After trying everything from a 3 point chisel to using a dremel tool and cutting a slot in the head and attempting to use a screwdriver, nothing... Just my luck, one freaking bolt wont come out. I ended up putting a 1/2" dia sanding tool on the dremel and spent the next 2 1/2 hours cursing bent over under the hood and sanding the head off the bolt. I guess after that bolt murphy had left my side and on the fuel bowl and HPOP o-ring replacement everything else went fairly smoothly.
Lesson Learned Never ever use 12 point sockets on anything a PSD!
Best part of it all I fixed it myself, saved a butt load of cash and no more leak!!
Old 09-10-2013, 09:58 PM
jcrammell's Avatar
jcrammell jcrammell is offline
jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.
Man that sounds just like my luck. Glad you got it fixed.
Old 09-10-2013, 10:13 PM
petrokiller's Avatar
petrokiller petrokiller is offline
petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.petrokiller has a great reputation on FTE.
10-4 on the 6 point, local ford diesel shop here gave me hint about the 6-point.
Bought a couple sets of new craftsman box end on amazon.
Good job on the fix.
Later
Old 09-10-2013, 10:17 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
oh the fun of working on stuff.
FYI if you have a good mig welder you could welded a nut on the end of it.
Old 09-11-2013, 04:39 AM
Tugly's Avatar
Tugly Tugly is online now
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Dude... that is sooo something that would happen to me.
Old 09-11-2013, 08:33 AM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
I only use 12 point sockets on 12 point bolts.
Period.
Good to see everything else went smooth after that though.
Old 09-11-2013, 08:48 AM
microdevil45's Avatar
microdevil45 microdevil45 is offline
microdevil45 is gaining momentum as a positive member of FTE.
Quote:
LOL I'm with Him ^^^^^^^^^^^^^^^^^^^^^^
7.3L oil leak?? look here Redsundevil 1999 - 2003 7.3L Power Stroke Diesel 133 Yesterday 01:48 PM
Missing under part throttle only... injector o-rings? lemonshindig 1994.5 - 1997 7.3L Power Stroke Diesel 12 04-26-2015 03:09 PM
EGR Cooler / Oil Cooler / Lessons learned walrus 6.0L Power Stroke Diesel 6 02-04-2015 10:33 AM
2000. 7.3l Fuel bowl and HPOP orings Punisher29073 1999 - 2003 7.3L Power Stroke Diesel 5 01-28-2014 06:27 PM
Motor is out. What to re-seal? Jeepincj7 1994.5 - 1997 7.3L Power Stroke Diesel 4 12-30-2013 09:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
