79 4X4 conversion with 71-72 parts
i have a 79 F-250 4X2 that is in very good shape.
a guy about 30 miles away has advertised a 71-72 4X4 running gear on craigs list for $500
can i put the front axle and divorced transfer case in my 79 to make it 4 wheel??
here is his ad.
8 lug 4X4 ford pickup driveline, engine, and trans
here is his ad.
Received 3,090 Likes
on
yes, what year?
and how will i make the front spring hangers because i now have coil springs and i know the 4X4 trucks have leaf springs.
the transfer case is just as simple as puting the mounts to the frame and bolting it up, rite?
plus, what about steering box, is the 2 wheel and 4 wheel the same?
on
not sure on what year the front 60 is, it was in the truck when i bought it. and i am going on what the guy i got it from said.
this is about the best picture of the front i have.
not sure on what is needed to put the leaf springs on a 2 wheel frame, all i have is 4 wheel trucks.
the 2 wheel trucks use upper and lower control arms, correct?
and are the 2 wheel frames boxed like the 4 wheel frames, or are they more of a "C" channel frame?
if it is a boxed frame, i would imagine all you need to do is drill for the shackle mount and front hangers, and maybe weld a collar in the frame to stiffen it
