F100 wheeler build
#46
#47
For the most part .035 hardwire on a wheeler is totally fine. For heavier plate you can also setup your machine to spray transfer mode. It's not a setting on the machine it's basically just hard wire with about 27 volts and lots of wire speed, probably around 400.
Welding will have less of a crackling sound and have more or a quieter humm.
If you've never heard of spray transfer setting read here. How to Mig Using Spray Transfer - Mig Welding Settings for Spray and Short Circuit
You will only be able to weld flat and horizontal as your puddle is too hot. Out of those positions with heavy steel is where again flux core has the advantage. That big dirty pipe pic I posted you couldn't do in spray transfer setting. A bottle with more argon percentage is reccomended they say but I've still used a 75/25
#48
Received 3,102 Likes
on
#49
#50
#52
#54
#56
#57
I'm just confused why the ram tabs have plate doubled then welded. Is it you just like to sit at a bench to weld more? I'd just of gone with thicker plate.I'm confused why it bothers you so much. There's lap plates all over the truck. You seem to like to replace all your sheet metal when you get a dent, what's the big deal if I put some extra welding time in? Not a big fan of the weave weld, and I prefer using flux core wire for better strength. I don't weave, flux core is gay, and if I was worried about a lack of strength I would tig weld it all Alot seems like overkill like the shock brace now over motor. What is overkill about that? Overkill is a funny word coming from a guy with 16' of lift, an innie and outie cage, and jib cranes. Link tabs look like 1/4" steel. 3/8 or 5/16 would be much more beef. So is it overkill or is it not beefy enough? They're 3/16 with 1/8 welded on. Of course thicker steel would be more beef, it would also be more overkill which seems to chaff your nuts
Nice looking pieces and fit up though. Plans to paint or u just gonna let er all rust? It will be painted
How thick is the diff over? flange section looks like 1/8 or 3/16. I'm guessing its on old cover,flange section?It's all 3/16, no old diff covers involved
#58
lucky 13, it all looks plenty strong to me, who cares if you have multi layers vs one thicker chunk.... I've done **** both ways, and both work fine.
#60
