Power Loss. FOund Solution!
early last week I took my PCM out to get the codes off of it for the chip I plan to get. Anyway, a few days after doing that I was cruising down the road and my truck did a quick nose dive with power loss. I thought nothing of it. I was on my home Sunday night and the truck did the nose dive again. So I started to slow down, because I had to turn, and decided to come to a complete stop and maybe do an acceleration test to see if it would do it again, the truck had just been started after 24 hours. Once I cam to a complete stop I looked down at the dash, my RPMs were at zero and the battery light had come on. The truck was completely dead. I turned the truck off completely and turned on to where the plugs kicked in, waited until the light went off and it rolled over just fine.
Once I got home I called my buddy, Diehardstroker, we talked for probably an hour and couldn't come up with a solution so I told him if it happens again I would let him know. I was on my way home from work yesterday and my truck took the nose dive power loss again and this time the check engine light came on. The instant I saw that light come on I knew it had to be the PCM! I remembered when Diehardstroker first tried to install his chip the truck wouldn't start and the check engine light was on because of a bad connection. I called him back to tell him it did it again and while I was on the phone I figured why not start the truck up again. I started it up just fine, no lights, I barely touched and moved the PCM and it shut the truck off. I found the problem!! I tightened down the nut under the hood, started the truck back up, shook the PCM and I went on merry way!
I just thought I would fill everyone in on my issue and solution! It had me worried for a second. If It kept doing it I definitely would have had to make a thread asking all of you.
voltfox
09-21-2015 04:46 PM
