'55 f100 window regulator - Ford Truck Enthusiasts Forums
Old 09-09-2013, 07:38 PM
Daddyo's garage's Avatar
Daddyo's garage Daddyo's garage is offline
Daddyo's garage is starting off with a positive reputation.
Hey guys! Anyone know if I you can rebuild a driver's side window regulator, or do I need to get a new one?
Old 09-09-2013, 08:19 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Try these folks for parts. I've replaced a couple crank studs. Boils down to how much time you spend repairing vs replacing. A long time ago an old boy told me that "If it is steel, it can be repaired."
http://www.midfifty.com/search.php?s...ndow+regulator
Old 09-09-2013, 09:03 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
I rebuilt one in a 54. Honestly, the best solution is to be a GOOD used one (easier said than done but possible), second a new Chinese knockoff (quality sometimes questionable) and third rebuild what you have. The studs aren't bad to do but if the gear teeth is stripped, riveted loose, etc. it takes time and often isn't worth it. Good luck.
Old 09-09-2013, 11:50 PM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
Quote:
I rebuilt one of mine and several on other old cars. My .02 is....
#1 Good used
#2 Rebuild yours with good used pieces
#3 Nos if you can find it, but $$$
A repo if you must, but just to hold you over until you decide on #1-3.
Old 09-10-2013, 07:19 AM
james G. phillips james G. phillips is offline
james G. phillips is starting off with a positive reputation.
Go to ebay motors website. Type in 53 F100. Go to page 2. A guy has two .He has taken out both regulators to install power windows and starting bid at $40.00. They would be well worth it for that price.
Old 11-01-2013, 10:25 AM
Can you use parts from the passenger side to fix the drivers side?
Old 11-01-2013, 10:26 AM
Can parts from the passengers side be used to repair the drivers side?
Old 08-12-2014, 12:12 AM
Well....... I found a deal on a repop for $40 so I went for it. Today it stopped working. Acts like stripped gears. Should a known! Figured I'd get by till I could replace or rebuild the old one. Oh well..... I don't think it lasted a month. 😕
Old 08-14-2014, 12:33 PM
gerrymoe's Avatar
gerrymoe gerrymoe is offline
gerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to behold
I have one that looks to be in good shape, splines on handle crank shaft look good, all teeth are there on regulator, probably needs new roller mechanisms. You can have if you can come get it or arrange shipping or send me the shipping costs I'll box it and send it to ya. Another way is I'll be in Morro Bay CA for the North South run, if you are coming or know anybody in the pick-up Limited F-100 club who is going I would be glad to give to them just need info
Gerry
Window regulator rews2 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-10-2016 04:27 PM
window/regulator removal magicbus 1947 and Older Ford Trucks 19 12-07-2015 06:13 PM
Manual window regulator 82fordowner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 05-29-2015 03:05 PM
Window regulator springs fell off Kamstutz 1999 to 2016 Super Duty 0 05-09-2015 05:54 PM
WINDOW REGULATOR BOB FERGUSON Ford Truck Parts for Sale 0 07-25-2014 05:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
