transmission plate bolt size
Old 09-09-2013, 05:48 PM
jpearson311's Avatar
jpearson311
jpearson311 is offline
Hi all. I have a 1977 Ford f100 2wd 4 speed manual 302 5.0. I just replaced the starter and now noticing a knocking sound when I push the clutch in. When I was replacing the starter on Saturday, I noticed this thin steel plate that was sandwiched between the back of the engine and the bell housing of the transmission. The bottom 3 bolts are missing and I thought that might be the problem. Like it's rattling when I push the clutch in. does anyone know if this is my problem? Also, do you know what those bolt sizes are? I'm assuming they're the same size as the starter bolts, just shorter. Thanks!
nathan328
06-20-2017 02:08 PM
shore
Modular V10 (6.8l)
09-27-2013 08:03 PM
Ford4Life7.3
23
12-13-2011 04:20 PM
radmacks
09-11-2011 05:40 PM
ETHEL
04-25-2007 11:43 AM
Quick Reply: transmission plate bolt size
