Spare tire lowering - Ford Truck Enthusiasts Forums
Spare tire lowering
Old 09-09-2013, 06:25 PM
Piffery1 Piffery1 is offline
Piffery1 is gaining momentum as a positive member of FTE.
Spare tire lowering
Recently purchased a 2003 F150. The other night I went to lower the spare and found the "Key" to the lowering mechanism was missing. Upon further checking I found that the key had apparently been wrung off in the lowering unit shaft end; the little star shaped slot that mates with the key is filled with a hard material which I assume is the remains of the key. Tried to pick it out with a long screwdriver to no avail, so even if I had access to the proper key I couldn't get in the slot. I'd really like to lower the spare without resorting to cutting the cable. Any ideas on how to do it? Thanks, Piffery1
Old 09-09-2013, 09:57 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
I would cut it and if you want to put it back there, stop by a salvage yard to replace the parts. Probably not what you want to hear.
Old 09-10-2013, 12:07 AM
After several hours of beating, banging, bumping and blasphemy I was able to get a long narrow blade screwdriver lodged in the keyslot and managed to lower the spare and then remove the whole mechanism. After cleaning out the keyslot it looks like it may be still usable with the proper key.
Thanks,
Piffery1
Old 09-10-2013, 09:57 PM
Glad it worked out. I know that was a lot of work.
Old 09-11-2013, 12:42 AM
Spare
Once I got the winch off and on the workbench, I found I could remove the keyed section from the winch shaft and the regular crank fits in its slot perfectly. Piffery1
Old 09-13-2013, 09:12 AM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
I have a replacement key lock set that I'm willing to part with if you're interested. PM me for more information.
Old 09-13-2013, 03:50 PM
Thanks for the offer but I'll do without! Piffery1
Old 09-14-2013, 08:04 AM
SC_Hoaty's Avatar
SC_Hoaty SC_Hoaty is offline
SC Chapter LDR
SC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputation
The part that the key mates into can be removed, and a rectangular slot remains. It fits nicely with blade end of a tire iron. Sounds like that is what Piffery1 did.
There are some good Youtube videos that show how to remove it. I had to do this when I bought my SuperDuty.
Glad you got it worked out! Good Job!
No spare tire key bachus 1999 to 2016 Super Duty 10 09-16-2016 02:32 PM
making a spare key jake22si 1997 - 2003 F150 6 10-27-2014 01:18 PM
Engine Analyzer Manual? Piffery1 Garage & Workshop 14 02-24-2014 12:03 AM
New to me... 2000 F250 Crew Cab 4x4... No Key for spare tire... F0rdFre@K 1999 to 2016 Super Duty 3 09-24-2013 10:26 AM
Fuel Pump Driver Module Piffery1 1997 - 2003 F150 0 09-09-2013 06:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
