transmission please help
My 0.02 USD worth . . .
Hey, overposting the same question won't get it answered any quicker. Thought I would throw that out there for reference. Also, as a side note, when you're posting about your truck's problem, keep everything in that same post. Don't start a new thread because the CEL light is on now or something stopped working after the last round of test & repair. It helps us to give you relevant information if it's all in one thread.
Down to business. Just to keep things simple, compatible transmissions would be '95 or '96 Bronco I6, 302, 351, '95 or '96 F150/250/350 I6, 302, 351, '97 F250HD/350 I6, 302, 351.
'94's and older E4OD's would not be recommended because there was a Ford mod in '95 that moved the protection diodes from the solenoid pack to the PCM and the plug on the right side for the Solenoid Pack was changed.
Keep in mind that there are two xfer cases; manual shift and electric shift on the fly. Unless you're going to re-use yours, pay attention when pulling the transmission.
If you're going to this much trouble, install a new TC bushing and seal in the pump and new output shaft seals. Drain the TC, fresh filter with a Filter Retention Clip and do not forget to flush your cooler lines if you had a catastrophic trans failure.
Hope this helps.
Ray
Hope this helps.
Ray
richdavis69
01-07-2011 05:55 AM
EPSNOW
12-21-2003 08:27 AM
