NP 435 ?
NP 435 ?
I've read a few posts saying the np435/dana 21 combo is basicly an orphan set up-- as in nothing will adapt to 435 trans. But no one says why or how to solve the problem. I have a 76 f100 with this combo and am looking to swap in a different t-case for low range work. I'd really like to go with the 203/205 setup. So how about some specific answers please? Change output shaft? Change adapters? Whats gonna work? I find it hard to believe nothing can be done. It may be a pain, it may require hard to find parts, but there has to be a solution. Thanks.
NP435 Np203 Np205 .. The assembly measured from front of transmission to centerline of rear output yoke is only 34" .. Have a look
I will ignore your comment since you're new around here looking for help because there are few other sites to answer your question.
Not much difference. The bolt pattern is the critical point. Why you ask? If going with a married t-case or doubler, then it's a 4wd version that is needed. Divorced t-cases in 4wds and 2wd trucks have the 2wd version including the married situation of a NP435s with a married Dana 21 t-case which also features a 2wd pattern. Dunno why.. it just is. You are welcome to contact Novak if you really must know.
I believe that 203/205 doubler set up comes from Offroad Designs.
You're welcome... in advance.
sunbelt57
10-26-2016 08:02 AM
6978sghfbjklgdfsjhkl
02-11-2015 06:00 PM
tukes48
12-26-2004 08:19 PM
