2007 Edge PCM Coils Problems - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 09-08-2013, 12:41 PM
ML190's Avatar
ML190 ML190 is offline
ML190 is starting off with a positive reputation.
Nearly six weeks ago I had a coil go out while driving home in the Edge. Unlike every other Ford I've had since 2001, when the coil goes out in an Edge it burns up the PCM for you too.
I replaced all the coils and plugs and sent the PCM off to be repaired. ($200 repair vs $1200 for a new PCM from Ford). The PCM repair guy calls and tells me mine is beyond repair so he sends me a reman one. Install the reman PCM, but have to have it flashed so the Edge will actually start.After having it flashed the shop calls and says the PCM is bad and that it burned up another coil on a different cylinder than before. Send this PCM back to be warrantied but find a used PCM while I'm waiting on the other one. Install the used one and it's bad causing a coil #2 to not fire but the others are firing.
Am I having a run of bad computers or could there be something else cause the computers to fry? The original diagnostic from Ford stated faulty PCM and coil #6 needed replaced. I'm getting tired of spending money on this thing and really want it back on the road. Any help would be greatly appreciated.
Old 09-10-2013, 08:28 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is online now
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Ford updated the pcm, coils, and spark plugs for this problem. They need to be replaced together as a set or the old coils will burn up the new pcm. I would bite the bullet and install Ford parts. That way you know its fixed and will stay fixed.
Old 10-05-2013, 01:52 PM
ML190's Avatar
Fixed....
The problem was a series of bad computers. Finally received a good PCM and all is well. Only took a little over 2 months to figure it out.
Old 12-22-2015, 02:07 PM
Shappard1 Shappard1 is offline
Shappard1 is starting off with a positive reputation.
2007 Ford Edge PCM failure and Coil melting
While driving, car started sputtering and vibrating. I made it to my Mechanic, barely. He said coil melted and that it continues to fire and sends a surge of power back to the PCM (Powertrain Control Module). He stated it was a faulty design in the PCM because when the coil goes out it should stop firing. He said that only the ford dealership could fix it and said to have it towed. If I tried to drive it any more it could catch fire and burn to the ground.
I towed to Ford and they stated this was a common problem and they have a TSB on how to fix. They stated there was a design issue with the PCM in Ford/Mercury/Lincoln in some range of years that included 2007 edge. They had 3 or 4 in the shop right then to fix the same issue. The estimate to fix was $2,958.
This is NOT normal wear and tear and a design issue. If a coil burns out, it is a $100 fix (very easy do it yourself) or $200 at the shop. Instead, the PCM fries all the coils and its self and you have to replace it all with their new and improved model they came up with.
If you have this issue, please call and report at:
Ford Claim: 1-800-392-3673
and
NHTSA: 1-888-327-4236
This issue needs to be reported for possible recalls or reimbursements.
Old 12-28-2016, 12:25 PM
bwombat bwombat is offline
bwombat is starting off with a positive reputation.
2007 Ford Edge PCM and coil melting very similar to what Shappard1 reported with the same repair. Cost is over $2500 to get this vehicle back on the road for what amounts to a failed coil ($150) on one cylinder that in turns fried two other coils and the PCM. Apparently there is a ford TSB that recommends replacing the PCM, all the coils and all of the spark plugs when this occurs.
1995 F-150 Code 173 & Poor Drivability omar1746 1987 - 1996 F150 & Larger F-Series Trucks 4 03-15-2016 09:43 PM
Transmission Going into "Safe Mode" Joseph D. Kendall 6.0L Power Stroke Diesel 34 01-12-2016 08:54 AM
Technical help needed Rider48 Modular V8 (4.6L, 5.4L) 2 06-19-2015 10:26 PM
"Why is truck trying to stall/quit out on me?" hunter301 1999 - 2003 7.3L Power Stroke Diesel 59 04-04-2014 08:54 AM
I really don't want to take my truck to the dealership. bigTEE56 1987 - 1996 F150 & Larger F-Series Trucks 29 05-24-2013 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
