np203 vs np205 - Ford Truck Enthusiasts Forums
np203 vs np205
Old 09-08-2013, 12:29 PM
swampthang swampthang is offline
swampthang is starting off with a positive reputation.
np203 vs np205
I have a np203 in my 76 highboy and it does fine for everyday use but I really would like to swap it out for a np205. The lack of 2wd kind of sucks at times. No big smokey burn outs and I'm sure that being in 4wd all the time has to lower my fuel mileage as well. I know the 203 is chain drive and that you can take parts from a 203 and add tem to a 205 and build an awesome tcase. I wouldn't mind building my truck up to tow better and maybe even take it to some truck pulls. What are your opinions on the 2 tcases?
Old 09-08-2013, 01:04 PM
Scifi266's Avatar
Scifi266 Scifi266 is offline
Scifi266 is starting off with a positive reputation.
if you have a 76 highboy it should be a divorced setup with the 205. If you have the and f100 4x4 then you would have the married 203. With the 203 you are only in 4 wheel drive when you have the hubs locked so you shouldn't see an insane decrease in mpg. most of what i have seen with the 203 and 205 is people stacking them together for some insanely lower gears for crawling.
Old 09-08-2013, 08:11 PM
Quote:
That's a negatory ghostrider. You can have a highboy with a divorced 205 or 203. F100's had a Dana 21 tcase that is one speed. If you have a full time tcase (np203) you would not have manual hubs.
Old 09-09-2013, 02:00 AM
jgavac's Avatar
jgavac jgavac is offline
jgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to all
Quote:
IIRC, you can get lockout hubs for the full time trucks. That was the whole premise behind warn hubs, being able to disengage the front wheels on full time 4x4 trucks. It wasn't a stock option, but is common aftermarket. That might have been what he was thinking of.
-Jameson
Old 09-09-2013, 09:40 AM
rogue40's Avatar
rogue40 rogue40 is offline
rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.
The full time transfer cases were also differential so that you could turn without binding. If you just added lockouts then all the power would take the path of least resistance, in this case it would all go to the front, and the truck would go nowhere.
That is why you need the part-time conversion for the transfer case also.
If you have a "spooled" full time transfer case and lockouts then, no matter what, you are still turning all that drive gear up front and reducing street efficiency.
The 205s are the desirable transfer cases and can still be found readily cheap in both married and divorced version.
Transfer Case Question pumpdriver20 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-09-2011 10:46 PM
Divorced NP205 Crossmember AK FORD GUY 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-12-2010 12:01 AM
np203 cies_69truck Clutch, Transmission, Differential, Axle & Transfer Case 2 05-03-2010 01:07 AM
Full Time 4wd to Part Time 4wd longhorns13 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-30-2009 10:12 PM
np 203 to np 205 conversion T.R.Bauer 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-17-2009 11:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
