2011 Expedition stuck in park - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 09-08-2013, 02:30 AM
bigblackbeauty bigblackbeauty is offline
bigblackbeauty is starting off with a positive reputation.
hi folks,
my 2011 XLT had an electric problem. Gear shift stucks in park position - bad fuse(breake light) has been replaced in that case - and it worked. So far so good - but this happened several times in the last 7 days and we run out of spare fuses.
My Ford dealer has replaced the electric connections within the trailer coupling after 5 days searching and billed over 500$. But yesterday it happened again. What i must say is, that the Expedition is very rare in germany and even Ford didn't sell it here(i imported this fancy car by myself). But has any one a suggestion, what i can tell the dealer/service team to find the cause?
It will be helpfull to get the wiring diagram for the shift lock solenoid or the brake switch.
regards from Germany...
Old 09-08-2013, 01:12 PM
rexster314's Avatar
rexster314 rexster314 is offline
rexster314 is starting off with a positive reputation.
Check the brake light switch. When it goes, it disables the shifter function as well
Old 10-08-2013, 11:10 PM
bunky383 bunky383 is offline
bunky383 is starting off with a positive reputation.
Quote:
I agree.
Also the service shop should be able to hook up their scan tool and be able to see if the brake pedal switch is closed or open depending on pedal position. If the pedal switch reads closed on the scan tool and you still can't get out of park, you may have a wiring issue between the brake pedal switch and your shift inter-lock, or the actual solenoid is on it's way out.
Blown fuse Stuck in germany 1999 to 2016 Super Duty 19 12-27-2015 01:10 AM
Electrical Problems 1ANZ 1999 to 2016 Super Duty 10 09-23-2015 11:20 AM
2001 Expedition XLT Electric Problems gasturbo Expedition & Navigator 5 09-18-2015 03:26 PM
2010 expedition won't crank Borolf 2007 - 2014 Expedition & Navigator 3 12-23-2014 01:44 PM
2011 ford expedition stereo wiring diagram bigblackbeauty 2007 - 2014 Expedition & Navigator 8 06-11-2013 10:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
