1976 ford f-250 highboy - Ford Truck Enthusiasts Forums
Old 09-08-2013, 12:01 AM
southernbrew96 southernbrew96 is offline
southernbrew96 is starting off with a positive reputation.
i want to bore my 360 v8 engine out to a 390. where do i look to buy a kit and what is the best brand to get? will it be difficult?
Old 09-08-2013, 09:21 AM
lurch460's Avatar
lurch460 lurch460 is offline
lurch460 is gaining momentum as a positive member of FTE.lurch460 is gaining momentum as a positive member of FTE.
The bore is the same between a 360/390, its the stroke thats the difference. Need a 390 crank and rods, I think pistons too. It would be just a regular rebuild after that.
Old 09-08-2013, 12:06 PM
Scifi266's Avatar
Scifi266 Scifi266 is offline
Scifi266 is starting off with a positive reputation.
Just a different rotating assembly like lurch said. You can get the kits of summit or ask a local machine shop as sometimes they can get you some good deals.
Old 09-08-2013, 12:21 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
As far as lift kits, there are a few companies that sale them. Skyjacker, Superlift, Rough Country, Tuff Country, Rancho, Fabtech.
Most offer a replacement set of front leaf springs and block for the rear. Or you can get a set of springs for the rear too, but most still use the OEM block.
Difficultly level all depends on your mechanical skills. A place to do it and tools makes it not so bad, IMO.
Depending on the amount of lift, will drive the need for things like longer shocks, soft brake lines, drop pitman arm, adjustable steering link, longer d/s.
Old 09-08-2013, 05:48 PM
riverguideguy riverguideguy is offline
riverguideguy is starting off with a positive reputation.
i have a 76 hiboy to . it doesnt have any lift and i have 35s on it but it looks like i could clear 38s if i wanted so unless you have 38s or bigger you really dont need a lift on a hiboy unless you just like the looks.
Old 09-08-2013, 06:24 PM
77&79F250's Avatar
Used OEM parts guy
Yea you have the 6 pk front leafs right? It all depends on how tired the springs are, I have seen wore our HB front springs that were almost flat....
The OP asked about where to look for a lift kit, what brand is the best, and how difficult it is to install. I gave him some direction on the lifts ect, but kept my opinion to myself on the best brand.
He did not ask what size tires he could run with out a lift or what size lift he need to run X size tires.....but I am sure its coming here shortly.
Old 09-08-2013, 06:32 PM
Quote:
Originally Posted by 77&79F250 View Post
The OP asked about where to look for a lift kit, He did not ask what size tires he could run with out a lift or what size lift he need to run X size tires..
did you wake up on the wrong side of the bed this morning? haha he didnt ask bout a lift kit either. he asked bout a 390 kit
Old 09-08-2013, 06:58 PM
77&79F250's Avatar
Used OEM parts guy
See that part about....
Quote:
Its all good....lol
determining truck build date Jaime74656 1999 - 2003 7.3L Power Stroke Diesel 1 12-25-2015 08:53 AM
Topless wpnaes Excursion - King of SUVs 26 07-15-2013 09:18 PM
Where is serial # on 1946 or 47 half ton pick up? Trulyvintage 1947 and Older Ford Trucks 3 05-20-2011 10:40 AM
I need HiSPL Testing..... 3 08-19-2009 05:52 PM
how do I know if I have a 400 Ford_Six 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 11-13-2002 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
