Finally had a chance to get started! - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 03-09-2014, 07:50 PM
ulev1st ulev1st is offline
ulev1st has a good reputation on FTE.ulev1st has a good reputation on FTE.
Had an hour or so to plat so.......
Had an hour or so to dedicate to the truck today before the NASCAR race so I started rough cutting some more steel for the bed.. I got the front of the bed next to the cab frame cut and fit. 1 x 2 14 ga....no welding today. Then I moved on to the "stake pockets". I used 2 in sq 14 ga tube for those. I purposely cut them extra long for later use.
I also tried just setting up one of the rear fenders to give me an idea about clearances.. with the mini tubs and the wider fenders I have 18 of internal clearance so I will be able to put a nice wide rim with some decent dish and back spacing and run a fatass tire on the back..That was important for the look I am going for.
  #107
Old 03-23-2014, 09:53 PM
A little more effort..
Today I had a chance to get the front (back) of the bed tacked in place and started getting the goodies together for the tail gate. Big thanks to Drewski 2 for the help with copying his design for the hidden hinges!
  #108
Old 03-30-2014, 09:15 AM
3/30/14
Today I finished the tailgate hinges and roughed up the frame for the tailgate..Again..a huge thanks to Drewski2 foir sharing his photos for the rest of us to benefit from!
  #109
Old 05-09-2014, 11:31 AM
Finally fixed my rear shock mount.
Today I spent an hour or so on fixing the lower rear shock mount... now it will have the correct geometry..
  #110
Old 05-09-2014, 01:25 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
Don, somehow I've been missing your recent posts on your build. Looks like your bed is coming along nicely. I'm glad to have been able to give you ideas to work with on your build. Looking forward to seeing your progress. You might as well get ready.........you'll probably be asked if you'd be willing to build another bed. I've had several people ask me if I would be willing to build one for them. Unfortunately, I want to keep this a hobby and not turn it into "work".
  #111
Old 05-09-2014, 04:40 PM
Thanks...I haven't had much time to dedicate to it lately... I will try to make more time for it...still working full time and family/grandkids make it hard to work on it as much as I'd like...
  #112
Old 05-09-2014, 04:58 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Great build you have going there Don,nice to see talent in action
  #113
Old 07-03-2014, 03:43 PM
Back on ut
Yesterday I started to find the floor in the shop..an hour or so into it...hey look...there's my truck....
Managed to get the running boards and rear fenders mocked up.. and the old part loaded on the trailer for a salvage run...
  #114
Old 07-07-2014, 01:35 PM
jbontke's Avatar
jbontke jbontke is offline
jbontke is starting off with a positive reputation.
Quote:
Originally Posted by ulev1st View Post
Got to spend about 4 hours on my heap yesterday.. I STARTED to mock up the front end...I got as far as installing the shocks and discovered that TCI shipped me the wrong coilovers..AND rear shocks..I guess I will give them a call on Monday!
I did manage to rough in the gas tank..It still needs a bunch of work!
What rear leaf spring setup are you using and what gas tank is that?
  #115
Old 07-07-2014, 01:48 PM
jbontke's Avatar
Quote:
Originally Posted by AXracer View Post
i hope your state allows bottom fuel tank pickups. that is illegal in many states. Not sure I'd be comfortable with mounting the fuel pump to the tank unsupported either.
How do you find out the rules of each state? Is NC one of the states?
  #116
Old 07-12-2014, 09:02 PM
Time for a cleanup of the shop
I finally got sick of not having a good clean place to work. So today it took me 6 1/2 hours but if found the floor of the shop today.
  #117
Old 07-14-2014, 10:17 AM
jbontke's Avatar
Quote:
I'll answer my own question here. It took so research but I found the TCI kit:
TCI Engineering ~ 1-800-984-6259 ~ American Made Street Rods, Hot Rods, Classic Trucks, Ford & Chevy Muscle Cars Suspension and Chassis Parts. Street Rods, Hot Rods, Classic Trucks Pickups
http://www.totalcostinvolved.com/pdf...Spring_Kit.pdf
  #118
Old 07-04-2015, 11:12 AM
Archangel007 Archangel007 is offline
Archangel007 is starting off with a positive reputation.
Running Boards
Don,
It has been twelve months and we are dying for an update - how goes it?
I would especially like to know about the running boards and whether you made those of were they an 'off the shelf' item?
If you made them yourself then nice work, and perhaps some close-up photos?
Cheerz,
Tricky
  #119
Old 12-20-2016, 09:05 PM
Believe it or not.....AFTER 2 1/2 YEARS OF WALKING AWAY FROM IT...... I actually found the truck again... after ALL THIS TIME!
I have been extremely busy but some things are in the works where I will definitely be getting back on the ole girl!
Effective 1 Feb, I will be officially retired and the plan is to get back on it until its DONE!
Money will be tight for a bit but I have managed to amass MOST of the parts I think I will need to finish her up.. I'm sure I have a few things missing but I will cover that when I run into them.
This week I finally decided not to go with the original instrument cluster and started working on modifying the original housing to accommodate new white faced SpeedHut speedo and gauges. I went with those for the ease of GPS based speedometer.. plus I like the vintage styling.
Getting EXCITED again!
  #120
Old 12-21-2016, 07:32 AM
Silver54's Avatar
Silver54 Silver54 is offline
Silver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to behold
Glad you are back at it Don, I will be reading through the rest of your thread later. Have a great one
1967 F-100 project 67nukeford 1967 - 1972 F-100 & Larger F-Series Trucks 869 02-22-2017 12:10 PM
Out with old. KsHighboy 1967 - 1972 F-100 & Larger F-Series Trucks 7 10-30-2016 10:20 PM
finally! official thread! dylansf23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 290 09-26-2015 07:55 AM
53 F100 start button did not want to work Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-13-2015 09:16 PM
Finally! jefrow03 1987 - 1996 F150 & Larger F-Series Trucks 6 04-20-2015 12:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
