Finally had a chance to get started!
#96
a whole lotta nothing accomplished today!
Just basically finished up the frame section for the actual bed. Made my own mini tubs out of a boat fender available at either Northern Tool ot Tractor Supply. Found the size I needed and ran a tape line and cut it down the middle...instant pair of mini tubs!
#98
Today we worked the bed rails a little bit and got the drivers side rough welded in..we made our ebd caps a little different than most...just to be different.. Also mounted the fan on the tabs that are welded to the radiator shell and mounted it....slow day not much to show but still progress!
#99
Don, out of curiosity, what is a ballpark figure on the price of the steel you bought for the bed construction? I built the bed for my truck before all of the increases occurred and just wondered how much of a difference there was. I did buy more steel than I really needed for the bed as I built my tailgate and running boards with the excess.
Been following along on your build...........nice job.
#101
This is what I have so far...
2 HR Sheet 14 ga..................47.33..............$94.66
1 SQ TUBE 2 X 14 ga.............34.49...............34.49
1 REC TUBE 1 X 2 .................25.51..............25.51
1 HR SQ TUBE 1 X 14 ga.........16.50..............16.50
1 ROUND TUBE 1 1/4 X 14 ga...20.07..............20.07
CUTTING CHARGE..........................................10 .00
TAX............................................... .................18.63
TOTAL............................................. ...........$219.86
Istill have to buy the flooring..thinking of using 1/8 Diamond plate steel.
#102
Are you considering building your tailgate?
#104
