Finally had a chance to get started! - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 11-01-2013, 09:35 PM
Last chance 53 Last chance 53 is offline
Last chance 53 is gaining momentum as a positive member of FTE.Last chance 53 is gaining momentum as a positive member of FTE.
Hi, First good with surgery! I was reading Your build thread and noticed your lower rear shock mounts, I believe you have them on wrong. The should be turned 90 degrees and swap sides. The upper and lower eyes should be going the same way to keep shocks from binding when rearend moves up and down. Maybe you allready know that but thought I would mention it. Nice truck and good luck with your health.
  #62
Old 11-02-2013, 12:02 PM
ulev1st ulev1st is offline
ulev1st has a good reputation on FTE.ulev1st has a good reputation on FTE.
Good possibility..the kit had no real instructions...I will look at that first when I am able to get back on it.
  #63
Old 11-02-2013, 01:45 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
GOOD CATCH! Last Chance, you are absolutely right, both the top and bottom pin axis needs to be parallel to the frame or you will soon break the lower eyes off the shocks.
  #64
Old 01-22-2014, 06:03 PM
Back in the shop!
Finally after what seems like forever ( actually onlt since 30 October) my son came over and I supervised some work on the truck!
He got it all stripped down to a bare cab and loaded on the trailer for me..it's off to the media blaster tomorrow! Yaaay!
  #65
Old 01-22-2014, 07:20 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
I am subscribed!Nice work,Love the AR wheels!
  #66
Old 01-23-2014, 10:01 AM
Jeff K's Avatar
Jeff K Jeff K is offline
Jeff K is starting off with a positive reputation.
Nice job...looking forward to more pics as you make more progress.
  #67
Old 01-23-2014, 10:08 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Very nice car trailer!
Nice work too!!
  #68
Old 01-24-2014, 07:24 PM
Fuel line ran
I had a couple of hours to kill today so I decided to run most of the fuel line..Basically I ran from the engine back to where the fuel tank will go,,It's 3/8 alum line and a few clamps..at least it won't rub or move around a lot.
  #69
Old 01-24-2014, 08:09 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Don, that's a nice clean job. It looks like you do not have a piece of hose between the engine and frame. You need a flexible piece in this location to allow for movement of the engine. Without it the hard line will eventually crack. Other than that it's looking good.
  #70
Old 01-24-2014, 11:30 PM
Didn't even think about THAT...THANKS for the tip Mike!!
  #71
Old 01-28-2014, 06:19 PM
Cab back from Media Blasting today.
As the title says I went and picked up the bare cab from the media blasters today..It has some ares of concern but overall I feel like it's in pretty good shape for it's age! Some minor patching will be needed.. By far the WORST of it is on the friont leading edge of the cab above the windshield on the drip rail....
  #72
Old 01-28-2014, 06:21 PM
a few shots....
  #73
Old 01-28-2014, 06:27 PM
Some more...
  #74
Old 01-28-2014, 06:45 PM
AXracer's Avatar
When you go to patch the roof, don't try to do it all at once. Start with making the compound curve corners and patching them then do the front and finally the sides. That joint is more complex than it looks at first glance, several pieces come together right at the gutter.
  #75
Old 01-28-2014, 07:49 PM
Rimrock F1's Avatar
It needs a little work but really...Not to bad. Looking at what you have already done I'm sure you can handle it.
Out with old. KsHighboy 1967 - 1972 F-100 & Larger F-Series Trucks 7 10-30-2016 11:20 PM
finally! official thread! dylansf23 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 290 09-26-2015 08:55 AM
53 F100 start button did not want to work Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-13-2015 10:16 PM
Finally! jefrow03 1987 - 1996 F150 & Larger F-Series Trucks 6 04-20-2015 01:32 AM
finally dynamic timed brokeasajoke Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 03-02-2015 02:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
