Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
FDinally had a chance to get started!
Old 09-07-2013, 07:17 PM
ulev1st ulev1st is offline
ulev1st is gaining momentum as a positive member of FTE.
I got an official start on my truck finally..my son and a friend came over and we just took off on her..a beginning pic at 9 am and how it sits at 6 pm.
__________________
Mustang Fanatic!!
Learning about Old Trucks!
Retired Marine...no better friend...no worse enemy!
Don
Old 09-07-2013, 07:26 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 is gaining momentum as a positive member of FTE.Marauder2004 is gaining momentum as a positive member of FTE.
Nothing like starting at a point where you can access all the important items. Good start!
__________________
Howard
1948 Ford F4
1992 F-250 HD 5.8 4x4
2004 Mercury Marauder 32v DOHC - sold in June. Don't create a screen name after a car you might sell!
1969 Marquis convertible, 429
Old 09-07-2013, 08:21 PM
zombiefied 247 zombiefied 247 is offline
zombiefied 247 is starting off with a positive reputation.
now time for the fun stuff good luck with your build post pics and keep us updated !!!!!!
Old 09-08-2013, 11:02 AM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Subscribing.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Sold for 9.5K
Don't just Modify it Fordify it
A Side Arm Is Like A Parachute, Tis Better To Have One An Never Need It, Than To Need One And Not Have It
Old 09-09-2013, 11:44 AM
Engine out..column out
SOOO many bolts in the fenders.....THREE holding to entire engine/trans in.Go figure! Front shackle hangers gave me FITS!
__________________
Mustang Fanatic!!
Don
Old 09-09-2013, 03:47 PM
Old School
Looking good. They sure come apart easier and cheaper than putting them
back together.
I like to get them running as what they are and drive them a bit and let
them tell me of what they want in the way of upgrades. I find this to be less expensive and gives me more motivation.
__________________
Old 09-14-2013, 01:48 PM
Rear suspansion mnocked up
I had about four hours today to mess with the 56 so I mocked up most of the rear suspensin and managed to knock one side for the C notch.
__________________
Mustang Fanatic!!
Don
Old 09-15-2013, 03:00 PM
Working on pass side "C" notch and mocked up engine today....
__________________
Mustang Fanatic!!
Don
Old 09-17-2013, 04:33 PM
Got to spend a couple of hours on her today.
Managed to get the old spring perch brackets cut of the Explorer 8.8 and got the new perches welded in place. So with the exception of throwing the U bolts on the bottom plates and installing the shocks the rear end is pretty much mocked up and square, plum and set at the correct pinion angle.
__________________
Mustang Fanatic!!
Don
Old 09-17-2013, 06:02 PM
dennisb56's Avatar
dennisb56 dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.
Wow your kicking butt. Nice work!
__________________
Dennis
52 F1
Coatesville, PA
Old 09-17-2013, 06:29 PM
Thanks Dennis..I have had the suspension parts for a while. I just haven't had any time until the past two weeks to play with it..After I get the front end installed I'll be back to the " saving up for parts" phase for a while.
__________________
Mustang Fanatic!!
Don
Old 09-17-2013, 06:52 PM
Schuyles's Avatar
Schuyles Schuyles is offline
Schuyles is gaining momentum as a positive member of FTE.Schuyles is gaining momentum as a positive member of FTE.
Schuyler Travis
Man looking good! I'm in the same boat, garage full of parts...but no time/friends to work on it.
Thanks for the motivation.
__________________
Schuyler
'65 F100 // 240/3spd/9" // power disc brake conversion
'56 F100 // 351m/c6/9" // Down and Forward springs/Sid's drop axle // Short and Smooth rear springs/extended rear hangers/adjustable front hangers
Old 09-17-2013, 09:03 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
I have all the parts, I'd give anything to have a friend/buddy to work with.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 09-17-2013, 10:15 PM
Ax...I am fortunate enought to have a friend who will help for free food...that works out good for me. My son lives close enough that he sometimes helps too. Like most on here I split my time between work ( I have a CRAZY schedule) and family time other interests, etc.
My drag car calls out every time I can make a Test N Tune session or local race, my other interests are NASA HPDE's and autocrosses in the area..sadly I haven't been able to make many this year..I sold my trailer and had to wait over three months for the replacement to be built..that pretty much ate into my open track days..I managed to make it one time to Barber this year...then it friggin rained all weekend..go figure!
__________________
Mustang Fanatic!!
Don
Old 09-18-2013, 05:00 PM
Slow day in the shop.
I got the old front crossmembers out of the way....SORTA on the back one...I just cut the center out for now.
Managed to get the front frame boxing plates in and sat the new crossmember in place just to get an idea how it would fit.
It is not even tacked...just sitting therre.
I SUPPOSE i should be happy that many years ago someone did one HELL of a job of undercoating the frame and body....but now it's a bitch to get that stuff off!
__________________
Mustang Fanatic!!
Don
Similar Threads
my truck wont start!!!!!!!!!!!!!!!! trevorrules 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2014 05:44 PM
2002 7.3 starting problem. vczar1 Excursion - King of SUVs 3 06-20-2013 08:16 AM
hard starting ahgoo 6.0L Power Stroke Diesel 3 10-10-2011 09:29 AM
starting mh5500 6.0L Power Stroke Diesel 4 08-11-2009 02:44 PM
No start mikewalsh1 1999 - 2003 7.3L Power Stroke Diesel 2 05-10-2006 05:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
