Finally had a chance to get started!
#106
Had an hour or so to plat so.......
Had an hour or so to dedicate to the truck today before the NASCAR race so I started rough cutting some more steel for the bed.. I got the front of the bed next to the cab frame cut and fit. 1 x 2 14 ga....no welding today. Then I moved on to the "stake pockets". I used 2 in sq 14 ga tube for those. I purposely cut them extra long for later use.
I also tried just setting up one of the rear fenders to give me an idea about clearances.. with the mini tubs and the wider fenders I have 18 of internal clearance so I will be able to put a nice wide rim with some decent dish and back spacing and run a fatass tire on the back..That was important for the look I am going for.
#107
#108
#110
Don, somehow I've been missing your recent posts on your build. Looks like your bed is coming along nicely. I'm glad to have been able to give you ideas to work with on your build. Looking forward to seeing your progress. You might as well get ready.........you'll probably be asked if you'd be willing to build another bed. I've had several people ask me if I would be willing to build one for them. Unfortunately, I want to keep this a hobby and not turn it into "work".
#111
#112
Received 4,118 Likes
on
#113
#114
Got to spend about 4 hours on my heap yesterday.. I STARTED to mock up the front end...I got as far as installing the shocks and discovered that TCI shipped me the wrong coilovers..AND rear shocks..I guess I will give them a call on Monday!
I did manage to rough in the gas tank..It still needs a bunch of work!
#115
#117
I'll answer my own question here. It took so research but I found the TCI kit:
TCI Engineering ~ 1-800-984-6259 ~ American Made Street Rods, Hot Rods, Classic Trucks, Ford & Chevy Muscle Cars Suspension and Chassis Parts. Street Rods, Hot Rods, Classic Trucks Pickups
http://www.totalcostinvolved.com/pdf...Spring_Kit.pdf
#118
Running Boards
Don,
It has been twelve months and we are dying for an update - how goes it?
I would especially like to know about the running boards and whether you made those of were they an 'off the shelf' item?
If you made them yourself then nice work, and perhaps some close-up photos?
Cheerz,
Tricky
Cheerz,
Tricky
#119
Believe it or not.....AFTER 2 1/2 YEARS OF WALKING AWAY FROM IT...... I actually found the truck again... after ALL THIS TIME!
I have been extremely busy but some things are in the works where I will definitely be getting back on the ole girl!
Effective 1 Feb, I will be officially retired and the plan is to get back on it until its DONE!
Money will be tight for a bit but I have managed to amass MOST of the parts I think I will need to finish her up.. I'm sure I have a few things missing but I will cover that when I run into them.
This week I finally decided not to go with the original instrument cluster and started working on modifying the original housing to accommodate new white faced SpeedHut speedo and gauges. I went with those for the ease of GPS based speedometer.. plus I like the vintage styling.
Getting EXCITED again!
