Finally had a chance to get started!
  #106
Old 03-09-2014, 07:50 PM
ulev1st's Avatar
ulev1st
ulev1st is offline
Had an hour or so to plat so.......
Had an hour or so to dedicate to the truck today before the NASCAR race so I started rough cutting some more steel for the bed.. I got the front of the bed next to the cab frame cut and fit. 1 x 2 14 ga....no welding today. Then I moved on to the "stake pockets". I used 2 in sq 14 ga tube for those. I purposely cut them extra long for later use.
I also tried just setting up one of the rear fenders to give me an idea about clearances.. with the mini tubs and the wider fenders I have 18 of internal clearance so I will be able to put a nice wide rim with some decent dish and back spacing and run a fatass tire on the back..That was important for the look I am going for.
  #107
Old 03-23-2014, 09:53 PM
ulev1st's Avatar
ulev1st
ulev1st is offline
A little more effort..
Today I had a chance to get the front (back) of the bed tacked in place and started getting the goodies together for the tail gate. Big thanks to Drewski 2 for the help with copying his design for the hidden hinges!
  #108
Old 03-30-2014, 09:15 AM
ulev1st's Avatar
ulev1st
ulev1st is offline
3/30/14
Today I finished the tailgate hinges and roughed up the frame for the tailgate..Again..a huge thanks to Drewski2 foir sharing his photos for the rest of us to benefit from!
  #109
Old 05-09-2014, 11:31 AM
ulev1st's Avatar
ulev1st
ulev1st is offline
Finally fixed my rear shock mount.
Today I spent an hour or so on fixing the lower rear shock mount... now it will have the correct geometry..
  #110
Old 05-09-2014, 01:25 PM
Drewski 2's Avatar
Drewski 2
Drewski 2 is offline
Don, somehow I've been missing your recent posts on your build. Looks like your bed is coming along nicely. I'm glad to have been able to give you ideas to work with on your build. Looking forward to seeing your progress. You might as well get ready.........you'll probably be asked if you'd be willing to build another bed. I've had several people ask me if I would be willing to build one for them. Unfortunately, I want to keep this a hobby and not turn it into "work".
  #111
Old 05-09-2014, 04:40 PM
ulev1st's Avatar
ulev1st
ulev1st is offline
Thanks...I haven't had much time to dedicate to it lately... I will try to make more time for it...still working full time and family/grandkids make it hard to work on it as much as I'd like...
  #112
Old 05-09-2014, 04:58 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
Great build you have going there Don,nice to see talent in action
  #113
Old 07-03-2014, 03:43 PM
ulev1st's Avatar
ulev1st
ulev1st is offline
Back on ut
Yesterday I started to find the floor in the shop..an hour or so into it...hey look...there's my truck....
Managed to get the running boards and rear fenders mocked up.. and the old part loaded on the trailer for a salvage run...
  #114
Old 07-07-2014, 01:35 PM
jbontke's Avatar
jbontke
jbontke is offline
Originally Posted by ulev1st
Got to spend about 4 hours on my heap yesterday.. I STARTED to mock up the front end...I got as far as installing the shocks and discovered that TCI shipped me the wrong coilovers..AND rear shocks..I guess I will give them a call on Monday!
I did manage to rough in the gas tank..It still needs a bunch of work!
What rear leaf spring setup are you using and what gas tank is that?
  #115
Old 07-07-2014, 01:48 PM
jbontke's Avatar
jbontke
jbontke is offline
Originally Posted by AXracer
i hope your state allows bottom fuel tank pickups. that is illegal in many states. Not sure I'd be comfortable with mounting the fuel pump to the tank unsupported either.
How do you find out the rules of each state? Is NC one of the states?
  #116
Old 07-12-2014, 09:02 PM
ulev1st's Avatar
ulev1st
ulev1st is offline
Time for a cleanup of the shop
I finally got sick of not having a good clean place to work. So today it took me 6 1/2 hours but if found the floor of the shop today.
  #117
Old 07-14-2014, 10:17 AM
jbontke's Avatar
jbontke
jbontke is offline
I'll answer my own question here. It took so research but I found the TCI kit:
TCI Engineering ~ 1-800-984-6259 ~ American Made Street Rods, Hot Rods, Classic Trucks, Ford & Chevy Muscle Cars Suspension and Chassis Parts. Street Rods, Hot Rods, Classic Trucks Pickups
http://www.totalcostinvolved.com/pdf...Spring_Kit.pdf
  #118
Old 07-04-2015, 11:12 AM
Archangel007's Avatar
Archangel007
Archangel007 is offline
Running Boards
Don,
It has been twelve months and we are dying for an update - how goes it?
I would especially like to know about the running boards and whether you made those of were they an 'off the shelf' item?
If you made them yourself then nice work, and perhaps some close-up photos?
Cheerz,
Tricky
  #119
Old 12-20-2016, 09:05 PM
ulev1st's Avatar
ulev1st
ulev1st is offline
Believe it or not.....AFTER 2 1/2 YEARS OF WALKING AWAY FROM IT...... I actually found the truck again... after ALL THIS TIME!
I have been extremely busy but some things are in the works where I will definitely be getting back on the ole girl!
Effective 1 Feb, I will be officially retired and the plan is to get back on it until its DONE!
Money will be tight for a bit but I have managed to amass MOST of the parts I think I will need to finish her up.. I'm sure I have a few things missing but I will cover that when I run into them.
This week I finally decided not to go with the original instrument cluster and started working on modifying the original housing to accommodate new white faced SpeedHut speedo and gauges. I went with those for the ease of GPS based speedometer.. plus I like the vintage styling.
Getting EXCITED again!
  #120
Old 12-21-2016, 07:32 AM
Silver54's Avatar
Silver54
Silver54 is offline
Glad you are back at it Don, I will be reading through the rest of your thread later. Have a great one
Quick Reply: Finally had a chance to get started!
