Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
  #106
Old 03-09-2014, 08:50 PM
ulev1st ulev1st is offline
ulev1st is gaining momentum as a positive member of FTE.
Had an hour or so to plat so.......
Had an hour or so to dedicate to the truck today before the NASCAR race so I started rough cutting some more steel for the bed.. I got the front of the bed next to the cab frame cut and fit. 1 x 2 14 ga....no welding today. Then I moved on to the "stake pockets". I used 2 in sq 14 ga tube for those. I purposely cut them extra long for later use.
I also tried just setting up one of the rear fenders to give me an idea about clearances.. with the mini tubs and the wider fenders I have 18 of internal clearance so I will be able to put a nice wide rim with some decent dish and back spacing and run a fatass tire on the back..That was important for the look I am going for.
__________________
Mustang Fanatic!!
Learning about Old Trucks!
Retired Marine...no better friend...no worse enemy!
Don
  #107
Old 03-23-2014, 10:53 PM
A little more effort..
Today I had a chance to get the front (back) of the bed tacked in place and started getting the goodies together for the tail gate. Big thanks to Drewski 2 for the help with copying his design for the hidden hinges!
__________________
Mustang Fanatic!!
Don
  #108
Old 03-30-2014, 10:15 AM
3/30/14
Today I finished the tailgate hinges and roughed up the frame for the tailgate..Again..a huge thanks to Drewski2 foir sharing his photos for the rest of us to benefit from!
__________________
Mustang Fanatic!!
Don
  #109
Old 05-09-2014, 12:31 PM
Finally fixed my rear shock mount.
Today I spent an hour or so on fixing the lower rear shock mount... now it will have the correct geometry..
__________________
Mustang Fanatic!!
Don
  #110
Old 05-09-2014, 02:25 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has a great reputation on FTE.Drewski 2 has a great reputation on FTE.Drewski 2 has a great reputation on FTE.Drewski 2 has a great reputation on FTE.Drewski 2 has a great reputation on FTE.
Don, somehow I've been missing your recent posts on your build. Looks like your bed is coming along nicely. I'm glad to have been able to give you ideas to work with on your build. Looking forward to seeing your progress. You might as well get ready.........you'll probably be asked if you'd be willing to build another bed. I've had several people ask me if I would be willing to build one for them. Unfortunately, I want to keep this a hobby and not turn it into "work".
__________________
Drew
55 F100 on the darkside.
Well done is better than well said!
  #111
Old 05-09-2014, 05:40 PM
Thanks...I haven't had much time to dedicate to it lately... I will try to make more time for it...still working full time and family/grandkids make it hard to work on it as much as I'd like...
__________________
Mustang Fanatic!!
Don
  #112
Old 05-09-2014, 05:58 PM
56panelford's Avatar
56panelford 56panelford is offline
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Great build you have going there Don,nice to see talent in action
__________________
John
  #113
Old 07-03-2014, 04:43 PM
Back on ut
Yesterday I started to find the floor in the shop..an hour or so into it...hey look...there's my truck....
Managed to get the running boards and rear fenders mocked up.. and the old part loaded on the trailer for a salvage run...
__________________
Mustang Fanatic!!
Don
  #114
Old 07-07-2014, 02:35 PM
jbontke's Avatar
jbontke jbontke is offline
jbontke is starting off with a positive reputation.
Quote:
Originally Posted by ulev1st View Post
Got to spend about 4 hours on my heap yesterday.. I STARTED to mock up the front end...I got as far as installing the shocks and discovered that TCI shipped me the wrong coilovers..AND rear shocks..I guess I will give them a call on Monday!
I did manage to rough in the gas tank..It still needs a bunch of work!
What rear leaf spring setup are you using and what gas tank is that?
  #115
Old 07-07-2014, 02:48 PM
jbontke's Avatar
Quote:
Originally Posted by AXracer View Post
i hope your state allows bottom fuel tank pickups. that is illegal in many states. Not sure I'd be comfortable with mounting the fuel pump to the tank unsupported either.
How do you find out the rules of each state? Is NC one of the states?
  #116
Old 07-12-2014, 10:02 PM
Time for a cleanup of the shop
I finally got sick of not having a good clean place to work. So today it took me 6 1/2 hours but if found the floor of the shop today.
__________________
Mustang Fanatic!!
Don
  #117
Old 07-14-2014, 11:17 AM
jbontke's Avatar
Quote:
I'll answer my own question here. It took so research but I found the TCI kit:
TCI Engineering ~ 1-800-984-6259 ~ American Made Street Rods, Hot Rods, Classic Trucks, Ford & Chevy Muscle Cars Suspension and Chassis Parts. Street Rods, Hot Rods, Classic Trucks Pickups
http://www.totalcostinvolved.com/pdf...Spring_Kit.pdf
Similar Threads
my truck wont start!!!!!!!!!!!!!!!! trevorrules 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2014 06:44 PM
2002 7.3 starting problem. vczar1 Excursion - King of SUVs 3 06-20-2013 09:16 AM
hard starting ahgoo 6.0L Power Stroke Diesel 3 10-10-2011 10:29 AM
starting mh5500 6.0L Power Stroke Diesel 4 08-11-2009 03:44 PM
No start mikewalsh1 1999 - 2003 7.3L Power Stroke Diesel 2 05-10-2006 06:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
