Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
FDinally had a chance to get started!
  #46
Old 10-15-2013, 07:45 AM
3golfjack's Avatar
3golfjack 3golfjack is online now
3golfjack is gaining momentum as a positive member of FTE.3golfjack is gaining momentum as a positive member of FTE.
Don,
Looks like you have made a lot of progress. Sorry to hear about the shoulder. A little time to do some strategizing never hurts.
__________________
Jack
1956 F100 http://www.ford-trucks.com/forums/11...ld-photos.html
1996 Ranger- daily driver
  #47
Old 10-20-2013, 07:37 PM
ulev1st ulev1st is offline
ulev1st is gaining momentum as a positive member of FTE.
Houston.....we have LIFT OFF!!
Today I managed to get the cab off of the frame..Now I will be able to get to the center section of the frame for cleanup and paint.
I bought some of that POR-15 from Eastwood..HOPEFULLY it's a good as they say it is. We shall see!
__________________
Mustang Fanatic!!
Learning about Old Trucks!
Retired Marine...no better friend...no worse enemy!
Don
  #48
Old 10-20-2013, 07:41 PM
One more Shot
Last one for tonight!
__________________
Mustang Fanatic!!
Don
  #49
Old 10-21-2013, 06:22 PM
Got the dolly made..(I am NOT a carpenter/framer!)
So after that I proceeded to remove the windshield. So now I can move where I need it and get to work on it.
__________________
Mustang Fanatic!!
Don
  #50
Old 10-21-2013, 07:04 PM
A couple of more shots.....
Meant to post THESE the first time..body isn't bad..no rust around either window..
The doors however are TOAST!
__________________
Mustang Fanatic!!
Don
  #51
Old 10-21-2013, 07:48 PM
Jeff K's Avatar
Jeff K Jeff K is offline
Jeff K is starting off with a positive reputation.
Impressive effort so far...thanks for keeping the pictures coming. Jeff K
__________________
1965 250 (428 FE)
1948 F3 (239 V8 Flatty)
Heb. 11:1
  #52
Old 10-21-2013, 08:12 PM
snook715's Avatar
snook715 snook715 is offline
snook715 is starting off with a positive reputation.
snook715 dlove123
Very nice work so far!
__________________
55 F100, 92 F250 2wd, 2013 Accord Coupe
  #53
Old 10-21-2013, 08:58 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a very good reputation on FTE.ben73058 has a very good reputation on FTE.ben73058 has a very good reputation on FTE.ben73058 has a very good reputation on FTE.
Hey Don,
We also used an Explorer 8.8 rear axle in our 1950 F1. One question on that - You have a large piece of flat metal welded to your round cross brace that supports the shocks. What is that for? We don't have one on our's - I'm wondering if I missed something... (wouldn't be the first time).
Our doors were also Swiss cheese all across the bottom. Good doors aren't as easy to find at least around here in Central Texas. We ended up doing a fiberglass job on them - not sure I'd recommend that route.
Looking good over there in Tennessee!
Ben in Austin
1950 F1
  #54
Old 10-21-2013, 10:33 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
They make patch panels for the door frame and outer skins. Mid Fifty says they are working on complete repop steel doors. Look for big job parts trucks, the cabs are all the same as the F100 the doors are often in good shape since they were so high off the ground, usually not worked as hard, and better maintained.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
  #55
Old 10-22-2013, 04:17 AM
@ben.........that is where I'm mounting my electric fuel pump and filter..didn't want it to free hang off the tank fitting
@Ax.THANKS for the tip!
__________________
Mustang Fanatic!!
Don
  #56
Old 10-25-2013, 09:07 PM
A bit more today..
Today was frame day..started off by stripping the frame bare and taking a wire wheel on a grinder to it.
Got most of the stuff off and managed to get the front C notches for the sway bar cut in.
Then it was time to apply the first coat of POR-15..I have tomorrow after work and Sunday after work to get back on it...then the surgery is Monday so I will have to leave it set for a bit.
I'd LIKE to get it back to a rolling chassis before that. We will see I guess.
__________________
Mustang Fanatic!!
Don
  #57
Old 10-25-2013, 09:37 PM
ben73058's Avatar
Hey Don,
Good luck with your surgery! You know they do make supervisory positions in this hobby. You could bribe some relative to carry on with the project while your wing mends. (I'm actually very good at the supervisory thing).
Ben in Austin
1950 F1
  #58
Old 10-25-2013, 10:34 PM
smallello's Avatar
smallello smallello is offline
smallello has a very good reputation on FTE.smallello has a very good reputation on FTE.smallello has a very good reputation on FTE.
Looks good! Good luck with the surgery.
  #59
Old 10-25-2013, 11:15 PM
GMbusa's Avatar
GMbusa GMbusa is offline
GMbusa is starting off with a positive reputation.
Looks great
  #60
Old 10-28-2013, 10:17 PM
Surgery postponed til Thursday......
So today I made an effort to get it back to a rolling chassis. I ran into a clearance problem on the brake booster so the soultion was to make spacers out of 1x2 tube to drop the trans crossmember down for everything to clear. Down side is it messed up the pinion angle so I have to deal with that...it's a learning process....but that's part of waht makes it fun.
__________________
Mustang Fanatic!!
Don
Similar Threads
Starting idiguy90 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 46 05-03-2015 11:03 AM
remote start kit wannabe7.3 6.0L Power Stroke Diesel 5 02-24-2015 10:21 PM
Starting issues travisg96 1987 - 1996 F150 & Larger F-Series Trucks 3 01-28-2014 10:59 AM
Ford V10 hard starting stan'37 Super Duty & Heavy Duty 17 08-30-2013 04:17 PM
2002 7.3 starting problem. vczar1 Excursion - King of SUVs 3 06-20-2013 08:16 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
