Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
FDinally had a chance to get started!
Old 09-18-2013, 07:55 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
That's an interesting crossmember, dropping in from the top, and different looking from the typical M II. What is it?
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 09-18-2013, 09:57 PM
fordman75 fordman75 is online now
fordman75 has a very good reputation on FTE.fordman75 has a very good reputation on FTE.fordman75 has a very good reputation on FTE.fordman75 has a very good reputation on FTE.
Is that a TCI crossmember?
Is the crossmember set in backwards? It looks the caster angle is the wrong way and the rack mounts are on the back side instead of the front.
__________________
Ted
1954 F100 4x4, 300, NP435/NP205
Old 09-18-2013, 10:05 PM
ulev1st ulev1st is offline
ulev1st is gaining momentum as a positive member of FTE.
It is the TCI coil over kit. I just sat it on the rails to get an idea of how it would look..it prob is in backwards...
__________________
Mustang Fanatic!!
Learning about Old Trucks!
Retired Marine...no better friend...no worse enemy!
Don
Old 09-18-2013, 10:12 PM
I just checked on their web site..it is sitting in there backwards!
__________________
Mustang Fanatic!!
Don
Old 09-22-2013, 01:16 PM
Weekend Update
Got to spend about 4 hours on my heap yesterday.. I STARTED to mock up the front end...I got as far as installing the shocks and discovered that TCI shipped me the wrong coilovers..AND rear shocks..I guess I will give them a call on Monday!
I did manage to rough in the gas tank..It still needs a bunch of work!
__________________
Mustang Fanatic!!
Don
Old 09-23-2013, 09:45 PM
Wrong coil over and rear shocks...missing C notch weld ins...
I got ahold of tech support at TCI today to see what could be done about the kit being different than the instructions..
First issue missing weld in C notches for sway bar..
Tech answer...Those are only for the Chevy trucks. The frame on a Ford isn't wide enough to need them...REALLY then WHY is it the instructions show cutting the frame and welding them in?
Issue TWO. The coil overs do not fit in accordance with the instructions..
Tech answer..Do your shocks say Ride Tech on them? YES they do. Well THOSE are designed to be installed upside down..we just haven't changed the instructions yet..(That was May of this year they changed vendors and the instructions haven't been updated yet!)
Issue THREE..the rear shocks I got have a stud mount on top..
Tech answer..Oh well those are wrong we will send you out the correct shocks..
Granted ,the quality of the IFS and welds etc are GREAT..but I would think that if you changed vendors and it required an update to the instructions that would clarify the kit changes that would be some good to know info...
Rant over.
__________________
Mustang Fanatic!!
Don
Old 10-01-2013, 05:35 PM
Motor Mounts roughed in....
Today I managed to get the motor mounts roughed in and tacked in place..
__________________
Mustang Fanatic!!
Don
Old 10-01-2013, 06:18 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to allbjmayberry2 is a name known to all
bjmayberry2
Lookin Good!
__________________
BJ Mayberry
Old Guy with Trucks
54, 56 F100s & 56 Ford panel
All works in progress
Old 10-01-2013, 06:28 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to beholdtinman52 is a splendid one to behold
Just curious, did you set your pinion angle with the rear suspension "loaded"?
Also, are you moving the front axle centerline forward so the wheels are centered in the fender?
Love '56's, wish I could find one around here.
__________________
Scott
'79 F250 DD, '62 F100 4x4, '52 F-1
My COE build thread;
http://www.ford-trucks.com/forums/11...uck-build.html
"you can call a pig a duck, but that won't make it quack!"
Old 10-01-2013, 11:53 PM
I have moved the front end a little not 1 1/2 inches. Closer the 3/4. I checked it loaded.. Minus the weight of the bed.
__________________
Mustang Fanatic!!
Don
Old 10-02-2013, 09:58 AM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has a great reputation on FTE.Rimrock F1 has a great reputation on FTE.Rimrock F1 has a great reputation on FTE.Rimrock F1 has a great reputation on FTE.Rimrock F1 has a great reputation on FTE.
Nice work and a good looking engine, it even has the distributor on the correct end
__________________
Mike.
1952 F-1 (Belle Pepper)
1956 Fairlane (Orreo)
2013 Taurus (Ginger)
2015 Escape (Rusty)
Old 10-05-2013, 06:21 PM
Test fitted some BLING today...
Test fitted some stuff today..BLING for the engine, master cylinder and some other stuff.
APPARENTLY these ALL INCLUSIVE , DOES EVRYTHING kits...are just a lot of raw materials that will work IF you modify them or re engineer..the rear shocks.....just don't fit!
__________________
Mustang Fanatic!!
Don
  #28
Old 10-05-2013, 06:37 PM
bjmayberry2
Don
Looks like you dropped some serious Jack. What did you go with?
__________________
BJ Mayberry
Old Guy with Trucks
  #29
Old 10-05-2013, 07:22 PM
It's the Eddie Motorsports kit..REAL NICE stuff! Billet front cover and they included everything EXCEPT INSTRUCTIONS!!!
__________________
Mustang Fanatic!!
Don
  #30
Old 10-05-2013, 07:34 PM
bjmayberry2
VERY nice!
__________________
BJ Mayberry
Old Guy with Trucks
Similar Threads
my truck wont start!!!!!!!!!!!!!!!! trevorrules 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2014 05:44 PM
2002 7.3 starting problem. vczar1 Excursion - King of SUVs 3 06-20-2013 08:16 AM
hard starting ahgoo 6.0L Power Stroke Diesel 3 10-10-2011 09:29 AM
starting mh5500 6.0L Power Stroke Diesel 4 08-11-2009 02:44 PM
No start mikewalsh1 1999 - 2003 7.3L Power Stroke Diesel 2 05-10-2006 05:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
