Truck starts cranking when batt. is connected. - Ford Truck Enthusiasts Forums
Old 09-07-2013, 05:29 PM
mandingo626 mandingo626 is offline
mandingo626 is starting off with a positive reputation.
Question Truck starts cranking when batt. is connected.
66' Ford econoline starts cranking as soon as I connect the battery cables. The ignition is off and I notice that the starter keeps cranking.
Before this dilemma, I had figured out that the solenoid burned out on me. I got a new solenoid and installed it. All the connections where back where they belong. So now my last step was connecting the cables to the battery.
Advice I took:
* disconnected small wires from the terminals that have "S" and "I". Reconnected the cables to the battery. Still cranked. They result could be a defective solenoid? Or the starter may have something stuck or welded to keep it cranking?
My point may be is how to test the new solenoid or what to start poking at the starter to see if it went bad. Please feel free to correct my questions, ideas or approach.
Thanks all Ford enthusiast for you recent tips and advice
Old 09-07-2013, 11:12 PM
kjhales kjhales is offline
kjhales is starting off with a positive reputation.
I have a 65 Econoline van. When I first tried to get the engine to run, after a couple of tries the starter relay (solinoid) seemed to weld the contacts closed. I replaced the relay, and after a few attempts at starting, the relay stuck ON again. Replaced the relay and it happened again.
I then replaced the starter motor ($70 for a Motorcraft core rebuilt in China from Autozone) and a new relay, and I haven't had any problems since.
Autozone checked the old starter and said it seemed good, but their test isn't under load. In my case, it seems the old starter under load was drawing way too much current.
Old 09-08-2013, 03:47 PM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
If you have disconnected the signal leads (small wires) from the solenoid, and it still sends power to the starter, then it is stuck in the ON position, and the solenoid should be replaced. Sometimes a whack with a hammer fixes it. Get a good quality replacement.
Old 09-12-2013, 10:52 PM
scoobyvanjack scoobyvanjack is offline
scoobyvanjack is starting off with a positive reputation.
like EmilBarnabas indicated the solenoid is stuck. you mentioned you used more than one replacement. One other thing to make sure is the battery is in good shape and can handle the load. A marginal battery will extend the start up curve (power required to initially spin the starter) and this will burn the commutator and brushes of the starter but also burn (pit) or weld the contacts in the solenoid. marginal doesn't ‎necessarily mean it won't crank but it will damage parts, also the cheaper the parts the faster the failure. so by all means "don' t by parts made in countries where the road have no name" it will sting a bit but some things pay to go O.E.M.
p.s. a weak battery will also beat up your voltage regulator and the alternator
Good luck, Oh yeah about advance auto i went through 3 generic ignition switches before i got one that work!
Old 09-15-2013, 08:03 AM
l8ntpianist22's Avatar
l8ntpianist22 l8ntpianist22 is offline
l8ntpianist22 is starting off with a positive reputation.
the only way this is possible is if you installed the bat cable together with the start cable, or the solenoid is bad if you had the trigger wire unhooked.
Old 04-29-2015, 02:10 AM
Back to replacing my alternator
Since the last post I have learned and repaired my 66' econo. After my 2nd time getting AAA to take my truck home, my educated guess is the alternator. Though to further advance, repair, and keep it functioning properly, does anyone know any links to obtain proper wire guage to the electrical components?
When i connect positive connector, engine cranks no matter what nathan328 1967 - 1972 F-100 & Larger F-Series Trucks 29 10-13-2016 03:44 AM
My Blue F100 HAS A SHORT, IM GOING NUTS! ford7377 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-09-2016 09:24 AM
Intermittent slow cranking AndreVR Ford Inline Six, 200, 250, 4.9L / 300 6 11-11-2015 02:18 PM
Help! '84 F150 starter won't stop turning shadetree enthusiast 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-18-2014 03:39 PM
Starter Solenoid Connections LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-08-2009 07:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
