Help! Starter issues - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 09-07-2013, 04:53 PM
Roswell Roswell is offline
Roswell is starting off with a positive reputation.
1990 bronco
Went to start it Thursday, put the key in the ignition and engaged starter.....engine did not start but starter stayed engaged and going....even after turning off the ignition and taking keys out. Starter kept going until it died.
Put on a new starter. When I went to hook up the battery the second I put on the second battery connector the starter engaged. No keys in the ignition.
So there must be a short somewhere......or could it be the solenoid?
Thoughts?
Old 09-07-2013, 07:37 PM
Southern Bronco's Avatar
Southern Bronco Southern Bronco is offline
Southern Bronco is gaining momentum as a positive member of FTE.Southern Bronco is gaining momentum as a positive member of FTE.
Starter relay(solenoid) is bad.
Old 09-08-2013, 10:23 AM
Quote:
THANKS!!!! replaced solenoid this morning - problem solved.
Old 09-08-2013, 12:30 PM
You are very welcome.
Old 02-09-2016, 11:40 AM
Texican1911 Texican1911 is offline
Texican1911 is starting off with a positive reputation.
How long did that last? Same thing just happened on my son's truck. Replaced the relay, next morning the starter seized. Replaced the starter, 12 hours later the battery has to be disconnected to stop it from spinning. Replace the relay again, 3rd start and it's doing it again.
Old 02-09-2016, 12:05 PM
ChiefM's Avatar
ChiefM ChiefM is offline
ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.
I would say you have a faulty relay, Just because it's new does not mean it's good. Cheaper ones are known to fail almost immediately, but check your wiring first.
Old 02-09-2016, 01:09 PM
Our longest time mechanic (I work at a Ford dealership) just said the Chinese ones generally can't handle the voltage and to get the Ford one. So that's what we shall do.
Old 02-09-2016, 01:31 PM
ChiefM's Avatar
I have seen it many times in the 73-79 forum. Since I have a 79 I have been trying to keep up on troubleshooting in case I run into any problems down the road .
Old 02-10-2016, 08:08 AM
axelgawn's Avatar
axelgawn axelgawn is offline
axelgawn is starting off with a positive reputation.
Well, My 73 dent truck will stay running and I can pull the key out when its started.
Truck Runs with Keys Removed Jmschneider 1973 - 1979 F-100 & Larger F-Series Trucks 18 10-12-2015 11:51 PM
What Just Fried? Jmschneider 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-14-2015 10:10 AM
Help! '84 F150 starter won't stop turning shadetree enthusiast 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-18-2014 03:39 PM
Starter issues J Lee 1987 - 1996 F150 & Larger F-Series Trucks 14 08-13-2014 11:29 PM
86 bronco starter will not disengage jhoopman86 1978 - 1996 Big Bronco 6 08-04-2010 09:30 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
